Doug1
"It is a generator, but I don't see that in the process where it
generates AC electricity. It seams to me the output would
be pulsed DC where the voltage starts at or near zero then
increasing to a maximum then decreasing back to the near
zero state.
AC as I know it starts at zero then increases
above zero then decreases below zero the same amount
it goes above zero returning to zero for the completion
of one wave."
Then explain a typical IC driven generator and we will see if you can answer your own question. Im not joking.
forest
Generators produce output by two methods (without considering resonance):
by positive feedback and by multiple induction.
There is no other way and everybody stating it is conversion of mechanical energy into current are fooled completely by priests of 200 years old ideology.
Think about it ... why Steven Mark was able to produce substantial output from almost zero input. The same are doing all generators today, while Figuera was a second , more controllable kind but also much more costly.
Doug1
 To the original question: Gens use a dc field winding and spin the magnet. When the magnet spins the field has direction of flow each time it turns 180 deg the flow is reversed in relation the output coils. With out the spin and making it stationary and wanting to still have a change in the direction of flow without reversing the domains of the core 180 which is very wasteful the options get pretty skinny. Take into account the time constants for a given field to reach the upper limit of saturation. Then add the load circuit for even more slowing down of the field building up. Then look at the no load condition of field magnet on a rotating gen compared to full load what is the difference in power being fed to the field magnet? If it ever drops to zero it no longer works. It has to be re-flashed. A certain amount of field is always present even at rest. It has to have a path for the flux which is primarily a closed path so it does not decay away into nothing. The Remanent single field even a week field will be in both parts but then you pull the cord or push the starter button and one part rotates while one part stays still. Picture this, you have an alinco magnet you break it half and run away with one half which half became empty? Does a gen look any different from a trofo now?
shadow119g
Word is out that you are building a new Professor Figeura system.
If you don't mind, I am of course curious to know what type of Part G you are
planning to use!
Thank you,
Shadow
If you would rather not, I understand.
