0 Members and 162 Guests are viewing this topic.
ramset
Note
I see T1000 posted while I was plunking this reply
my below reply was already written and in no way reflects on T1000's comments above
marathonman
I have a different perspective I suppose .....  I am grateful for the opportunity to have access to this forum and have no problem following the rules here because I am a guest.... as are you .
Everyday disagreements which happen here all the time are usually settled with evidence of a claim ....
not with threats of doing physical harm to persons here ,or any kind of harm for that matter.
there is only one reason you are still here .
Stefan is unaware of your behavior.
this has nothing to do with your work and everything to do with the liability you bring to his house.
this behavior is against the law ,and such behavior comes under increasing scrutiny  everyday that goes by as laws are passed to enable prosecution in the cyber world and address the concerns of violence and other abuse.
Stefan chooses to forgo the need to hire lawyers ...[yes HE is liable in the eyes of the law ]
and chooses instead to make this a non issue for him [ZERO tolerance].
if this is your path forward [threats of violence and ??
it is good you have a quiet place to go
Chet K
PS
honestly
you should already know this... it is written in the terms of service agreement you acknowledged and agreed to as part of your membership here.
Thanks Grandma
marathonman
Have you noticed the troll and shill went scampering into the dark when you posted. imagine that ! starting the fire then running like cowards that they are.
Look, i will very much tone it down if they get the heck off my back, quite posting erroneous information, failed attempts,  total unproven lies and some that doesn't pertain to the subject line.
Every thing i post can be verified by anyone with half a brain so i see no problem on my side. what i do see is the problem with trolls and shills that have NO PROOF i am wrong because they find it easier to run there mouths than doing the actual research.
I call everyone out on this troll web site to prove me wrong on the bench, i mean actual research from them not someone else failed attempt at replication.
again i will tone it way down but i want to see PROVEN bench work from the ney sayers that i am wrong in which i am not and can't wait to see their faces from their failed attempt to prove me wrong.
My bench work tells me i am right, what does yours tell you if you even did it in the first place. so tell me T-1000 have you performed any test that i have done and some i have posted here that can be done by you at your home that prove the actions of the NN facing electromagnet and the actual reason part G does what it does proven with Science and Physics, probably NOT. knowing how the device works is what i am trying to convey to  people but you only seem to be focusing on the final build. get off your butts and learn what i have been posting then and only then will you be ready for what i plan to present. until then try learning or get off my back. PLEASE !
Regards.
Marathonman
ramset
marathonman
in defense of readers here [and the many builders ]
there are tens of thousands of words written in this thread ....maybe Zillions over the years
too much to absorb or comprehend as a whole
you suggest
end quote
the above quote needs perspective....
is there a test/schematic which builders here can do at their home which will show an anomaly heretofore unknown or misunderstood??
can you post this NOW ?
Chet
Thanks Grandma
marathonman
Mr ramset;
  I really have to ask you do you really need a schematic to do the NN magnet test that proves the validity of the Figuera device.??? do you need a schematic to perform self inductance test that prove the validity of part G.??? do you need a schematic to realize when an inductor is reduced it releases that reduced potential into the system.??? do you need a schematic to realize when an electromagnet when reduced it releases that reduced potential into the system.
do you need a schematic to realize all these reduced potential causes an amplification to the rising electromagnets in part G which is an inductor.???
do you need a schematic to realize the magnetic field of an inductor causes a reduction of currant flow and the FACT that any change in the system that changes the ratio of magnetic field to currant will reduce or increase the currant flow.???
do you need a schematic to realize a resistor can not perform not one of these function except reduce the potential in the form of heat.????
Get real,
or do you need a schematic for that also.
Marathonman
seaad
MM
Need a schematic to understand the connection between part G and S-N coils. See the orange loop in  pic.
Regards Arne
