0 Members and 139 Guests are viewing this topic.
marathonman
My previous post stated in the most descriptive manor i can conceive yet you still can't understand it.... WOW!
Finally something we can agree on your not an expert or even close.
Totally wrong answer. the self inductance does not stop because of the constant rotation of the brush.  I REPEAT,  the self inductance does not stop because of the constant rotation of the brush.   this changes the ratio of flux to the currant on a continuous basis.
man do you people know anything about inductance. if the contact was stationary then your assessment would be correct but it isn't. it is dynamically changing as the brush rotates.
Quote from Wikipedia;
"Any alteration to a circuit which increases the flux (total magnetic field) through the circuit produced by a given current increases the inductance, because inductance is also equal to the ratio of magnetic flux to current."
what part of this statement do you people not understand?????? the brush rotating changing the length of the inductor on both sides of the brush will change the ratio of flux to the amount of currant. this is the alteration to the circuit as the brush rotates changing the ratio of flux to the amount of currant which is the reverse EMF to the original currant flow.
Plain English all day long but if i need to translate to another language for you people to understand i will. good god i have been harping this very thing for five years and still no one gets it. it's like talking to the wall on this web site. and you wonder why Doug quit posting to you people, i was the only one that listened to the wisdom or has sense enough to listen.
Marathonman
marathonman
The entire inception of the Figuera device was a journey of at least 10 plusyears. Figuera being unhappy with the present day !900) Generators that were called dynamos in those days that had massive cogging effects which were the result of the Lenz Law of attraction between the stator and the rotor attractive force when leaving register (alignment).
his 1902 patent was a rotating version  that was sold to the bankers then later he revised his patent to be non moving (1908). in the process of realizing that two opposing electromagnets compresses the magnetic field to that of a standard high intensity field generator. he then devised a way to vary them in an orderly fashion to induce motion into the secondary all while reducing the currant draw on them and using that reduction of magnetic field in a positive way to make the device self sustaining. with the use of a dynamic inductor he was able to use that magnetic fields in the core to reduce the currant in an orderly linear fashion and reuse that reduced magnetic field in the core of part G combined with the other reduced fields to give rise of amplification to the rising primaries.
in this process the currant was able to be split to two feeds allowing both sets of primary array's to be controlled independently but in absolute unison. each side of the brush's inductor either adding or subtracting winding's that magnetically link or unlink to the system which will cause the magnetic field collision point to be swept back and forth over the space occupied by the secondary.
once the secondaries are polarized and currant begins to flow in the secondaries and the load a second field forms in the secondaries that opposes the original currant flow (Lenz Law)  and it is this field that the opposing primary fields push or rather sweep back and forth over the space occupied by the secondary giving the appearance or allusion of motion to the electric field causing currant to flow in the secondary and the load.
if there is more currant draw on the secondary from a larger load the resistance in that part of the external system will drop and more currant will flow thus returning more currant to the beginning where the secondaries are connected to part G which will give rise to more potential to the electromagnets thus boosting the output to the secondaries and the load.
just like a standard generator does only stationary.
Marathonman
marathonman
This is a challenge to get people that are not use to a technology up to par and understand it's implications.
Taking a defensive position as always ? It is how you people cope with unknown and unresolved issues in new technology that just happens to be 110 years old.
Just because You don't understand it doesn't mean that it is NOT CORRECT...it just means you lack the brain power, intellect and power of reasoning to think outside the box understanding it's operating conditions. this device operates in accordance with all known applicable laws set forth by the founding fathers of Physics and Science and violates not one.
so my suggestion to all that don't understand it's working conditions and parameters should either learn how this device operates or quit posting on this thread entirely as you are nothing but a waste of this threads time, the readers time and my time.
post somewhere else if you can't understand it or don't take the time to learn. remaining completely ignorant is of course your prerogative just not my cup of tea.
Marathonman
d3x0r
Quote from: marathonman on May 07, 2018, 06:06:02 PM
Marathonman
I hesitate to mention this guy; he certainly doesn't need your attitude...
Quote from: marathonman on May 03, 2018, 10:28:26 PM[/size]
i have a home base that is quiet and i really don't need this BS if this is all it is about.
I AM MARATHONMAN
[/size]
You're the only one perceiving and being triggered by 'BS'; and although you are trying to trigger everyone else,  that's not a very good excuse to be defamatory and derogatory to everyone else.
https://www.youtube.com/watch?v=zebMvmVZyIA&t=0s
He's even got a span of resistor wire :)
I know; everything I post anywhere is off-topic so nyah.
marathonman
Just like i have been saying some just don't have what it takes to do research and conduct test thus have to rely on OTHER people doing the work for you.
I love the heater coil, it would be great in the winter time for heating the whole household up.
noting ones lack of intelligence is not defamatory is is the truth and on this site it seems to be the par for the course. why am i the way i am because most of the people that run their mouths have been the same one's from the start so after so many years it get really old.
so tell me brainiac how is the resistor array going to recycle the reduction of magnetic fields and use them in a positive way to off set the potential drop of the rising side.
Sorry charlie it is NOT and is Physically impossible. try proving it yourself instead of relying on other peoples work which seems to be the norm on this web side.
you people are unbelievable and totally lack what it takes to do research i guess that will prove everything i has stated. of course the easier road is denying it and running of the mouth.
I feel sorry for all of you.... NOT !
Marathonman
