0 Members and 54 Guests are viewing this topic.
citfta
Hello MM,
Let's try again to have a technical discussion about your part G.  You are claiming you part G can change the current flow through it by changing the flux through the core.  I am sorry but I have not seen any evidence that that claim is true.  The reason I doubt it is because the flux through your part G doesn't really change.  No matter where the brush is the current is divided between the two primary coils.  You have insisted several times that neither coil is ever really turned all the way off.  So that means there must be current going through both coils all the time.  Sometimes most of the current is going through one coil and sometimes most is going through the other coil.  But either way there is current always flowing through all the turns of your part G.  And those currents will always add up to the same amount of current.  So the flux is NOT changing from the difference in current flow if your claim is correct about always having both coils energized.
Instead of constantly posting bashing posts about others not understanding what you are claiming why not post a short video to prove what you say is true?  All you would need to show is a scope connected across one of your primary coils while part G is rotating.  The scope should clearly show a changing voltage being applied to your primary coil.
It should be clear to you by now that there are apparently no believers of your claims on this forum.  Show us the video and then some, like myself, might actually start to consider your claims as having some validity.  Claims with nothing to back them up are always going to be viewed with suspicion.
Respectfully,
Carroll
marathonman
Wow Cifta being civil, now i am impressed.
again your assumption is entirely incorrect as always. even though Netica did not have enough winding's on his part G it still worked and you know this but now you are claiming it doesn't work at all which pegs you as a complete liar and a fraud. all you and your kind do is blow smoke up peoples back side every single day and i laugh at you people because you don't fool me.
your total lack of knowledge in many areas shows quite well but the real fact is you people don't want to learn otherwise we wouldn't be having this conversation at all.
it's like if i had a lighter in my pocket and traveled back to the thirteenth century, the first time i struck it i would be pegged as using sourcery  thus would be beheaded. people even got beheaded for thinking the world was round. well you people remind me of these people completely ignorant to the facts but remain so as it is the safest option.
the only thing in your entire statement that is true is the fact that currant is always flowing through both of them but the rest falls flat on the floor.
If you people can't  or refuse to wrap your brain around a simple object and see it's implications then there is no video in the world that will change your completely closed minds.
I'm sorry it is your loss in not understanding this device as there is many out there that think otherwise that are not so closed minded as this group.
i will make a video in the future proving every one of you trolls wrong and i cant wait to see you all choke on your pride and misconceptions. i will rather enjoy destroying all of you in one fell swoop, a big pile of burnt pride and misconception. ha, ha, ha, ha!
PS. I'll start with pretty color pop-ups for your enjoyment and finish with pretty colored lights being changed in intensity in complete unison. i hope you and your troll friends enjoy the show.
Marathonman
d3x0r
Quote from: marathonman on May 08, 2018, 09:09:44 AM
so tell me brainiac how is the resistor array going to recycle the reduction of magnetic fields and use them in a positive way to off set the potential drop of the rising side.
Marathonman
First, if the content of the message was in english it might make cents.
recycle?  In what way is a magnetic field ever recycled?  collapse it back into current and then back into a field?  maybe something to do with resonance?  The Figuera devices use no resonance.
I suppose 'reduction' is 'production' ?
And the last part 'to off set the potential drop of the rising side.'
E = I * R;  a change in R always changes E and/or I.
But anyhow the magnetic fields are entirly relative to current and not voltage; so potential variation isn't really the issue anyway.
seaad
Quote from: ramset on May 04, 2018, 09:43:33 AM
marathonman
in defense of readers here [and the many builders ]
Is there a test/schematic which builders here can do at their home which will show an anomaly heretofore unknown or misunderstood??
Can you post this NOW ?
Chet
I'm sure MM can't make a  Figuera schematic with coil winding instructions and so forth. Which works.
He just want to act as a god, above us all.
We can meet at "energeticforum" without disturbance because MM is banned there (??): http://www.energeticforum.com/renewable-energy/12439-re-inventing-wheel-part1-clemente_figuera.html?highlight=Re-Inventing
Regards Arne
marathonman
ANT; See i rest my case. all you lower individuals have is an attempt that did not have enough winds just like i  have admitted in the first place. you are a complete fool ANT and have no business posting on any site from your lack of.
My present part G using the posts i have so stated work just fine no matter what you post or don't agree with, TO BAD.
When i post the video of the perfectly working part G you ANTS will get squashed.  OMG am i laughing at the sheer desperation of you troll in a massive attempt to discredit in which you are failing quite miserably.
I see the complete desperation in your action and i am still laughing at all of you, ha, ha, ha, ha !
Yes go back to the failed EF ANT with all you trolls as you will never get a free energy device running because of the lack of intelligence and proper reasoning skills.
you clowns spend more time crying, kicking and screaming like little children instead of actually doing the test that will prove the validity of my post with Physics and Science.
come one your failed attacks only make me laugh that much harder. i am digging the pit for all your burnt bodies after i prove every one of you trolls wrong. thus i will laugh and spit in your faces.
you people are NOTHING but trash and should be banned for life from ANY web site.
I think it is time to take out the trash don't you think.
Ramset pm me and i will set your mind at ease and prove once and for all this ANT is a complete fool that hides behind everyone else as his lack of manhood dictates he does.
you people are not only disgusting but utter fools dressed in purple and not worth ANY ONES TIME so there for you people are a total waste of time i am through with all you bums. i hope you people rot in hell.
Marathonman
