0 Members and 27 Guests are viewing this topic.
marathonman
This is an old picture of my primaries when i first wound them before the core was dropped. as you can see the bobbins are strong, work just wonderfully and the winding's are tight.
never underestimate your abilities to accomplish your goals. just because you have not done this before as myself also, doesn't mean you can't step out of your comfort zone which is 3/4 of the battle to accomplishing your task at hand.
the bobbins are snug on the core but can be adjusted if need be which is perfect when building in uncharted territories.
I honestly hope this tutorial can help many people out there that are contemplating or partaking in the building of the Figuera device or AMY device for that matter. ;D
Regards,
Marathonman
marathonman
I would also dwell on the fact of actually winging your own coils.
winding you own coils is a rather easy task if you have the right mind set that you can accomplish anything you set your mind to. i know some have seen my winder i have built but there is also some out there that have not and are probably not sure how to proceed. all of the parts used in building my winder tree was purchased at a local hardware store for maybe 25 to 30 dollars. the pipe in the picture is basic water pipe that is inexpensive that comes threaded and pre cut to certain length that are easy to handle. all the fittings can be purchased at the same place as the pipe. their were many people that ran their mouths and laughed at it thinking it was some kind of a joke but those are usually the ones that have no clue how to build anything by them selves and would rather put someone down as they lack any such skill. i personally like to share my experiences to make things easier for other not so experienced to achieve their goals.
the winder in the picture was purchased off of E-bay for some where around 65 dollars. the black knob on the right side of the winder can be taken off and attach a drill motor with a foot peddle controller to control the speed of the winder. by attaching the drill motor at this location all the torque is applied to that one single shaft and not to all the gears that way they do not strip out. then the gears are used just for the counter which counts the turns.
finding ways to get your task accomplished takes just a little thinking which seems to be lacking now a days. thinking outside of the box you will be able do just about anything you set your mind to.
The coil on the bobbin in the above post was wound with this winder and winding tree,  as you see it works wonderful.
Marathonman
marathonman
The whole idea behind the Figuera device is using two opposing electromagnets that compresses the field lines to match that of a standard generator. that's certainly not all though as just compressing fields line will not get an output because the both E fields are opposing at that point and no output will occur. so think about that for a moment, how will you get those E fields in the same direction to match one another. you take one up in currant and take the other down in currant at the same time allowing the E fields to match being positive and additive in their relation to each other. the difference between increasing one electromagnet is the same aspects as taking a magnet towards a coil and the decreasing electromagnet is the same aspect as taking a magnet away from the coil. the spin direction does not change but since the reducing one is catching the back side of the spin both E fields are in the same direction which is positive and additive.
since Faraday laid down the laws of induction there has to be some kind of movement in order to get induction from the electromagnet either being the coil of wire that moves or the increase or decrease of currant to the Electromagnets. this is still not all as the movement of the magnetic fields will cause the electric field but there still has to be movement of the secondary through the electric field in order to get currant to flow.
now things get tricky, how are you to get the secondary to move in a static non moving system across the electric field to get currant flow into the system. one might say that is impossible to do but Clemente Figuera was not an ordinary person and has figured this all out in his sheer genius mind.
what Figuera figured out was if two opposing fields had a secondary in between them with the primary raised and the other lowered in currant that the primaries will cause the secondary to polarize and currant will begin to flow in the secondary and the load. when this happens the secondary will form a secondary field to the first (lenz law) that opposes this field. the primaries and the secondaries then part ways and become separate systems. this opposing field of the secondary is what sandwiched between the primary opposing magnetic fields thus causing the sweeping action across the Electric field from the raising and lowering of the primaries controlled by the inductor part G.
in the actions of part G and the primaries, one side of part G and the primaries are raised and the other half is lowered in currant but in doing so the reduced magnetic fields release that reduced portion into the system along with the secondary loop back causing an amplification to the rising side of the system off setting the potential drop of the rising side as all rising magnetic fields there will be a potential drop across the conductor thus the three forms of potential will give amplification to the rising side of the system. as long as part G's positive brush continues to move you will get a constant change in the magnetic flux to currant ratio causing a very orderly linear rise and fall in currant in complete unison.
Marathonman
marathonman
I know i have said this before but i am going to say it again.
Part G can NOT be replaced so easily with electronics like everyone seems to think. why would someone want to over complicate something as simple as the Figuera device part G inductor is so way beyond me. sure i was to dazzled at one time by electronics but then i can to the harsh reality of just who was getting rich and who was not.  just stop and look around and seen the take over of your lives from these corporation that have you convinced you need electronics in your lives. all this does is make you LAZY and makes them RICH.
Part G is complicated yet simple at the same time. the main factor of the difficulty in using electronics is the release of potential from the reduced side to offset the potential drop of the rising side thus giving amplification. i am sorry folks but electronics can not ever do this in any way shape or form. at the very least one would have to combine the two having a core with electronic switching but even then the amount of transistors to mimic the brush rotation will be anywhere from 80 to 100 transistors and i am sorry but i refuse to handle over my hard earned cash to these monsters when all i have to do is use the core with a few cheap brushes.
with out a core and winding's to change the ratio of magnetic field per the amount of currant (C-EMF) on a continuous basis the complexity of using electronic just flew straight through the roof and i personally think the average person is not capable of doing this and would seem to be a waste of time.
Part G has many function and i really doubt you can mimic all of them with electronic but if one must go down that path i hope you are prepared to get a dump truck full of parts ready and one hell of a wad of cash.
part G spits the feed into two, forward biases like a mag amp, reduce and raises the currant on a continuous basis through self induction (C-EMF) stores and releases potential to either off set the rising side or stores the potential for the next half cycle along with the storing and released potential of the primary electromagnets then uses the secondary output to replace losses and amplification. all this happens inside of part G which will become the power supply one the starting is removed.
so one that note if you think you can mimic all those function with electronics  all i have to say is GOOD LUCK, you will need it.
Marathonman
T-1000
Hi all,
@marathonman
Can I suggest you just make video with experiment showing what you are trying to describe here? It would be much more helpful than walls of text which are just ignored here.
Thank you.
