0 Members and 54 Guests are viewing this topic.
seychelles
AND WHEN TESLA WAS ASKED WHAT WAS HIS GREATEST ACHIEVEMENTS
HE SAID IT WAS HIS ROTATING MAGNETIC FIELDS INVENTIONS. FIGURE THIS
OUT..
seaad
Quote from: seychelles on May 22, 2018, 03:53:53 PM
THE MAGNETIC FIELD HAS TO BE MOVING,
NOT JUST PULSING OR VARYING IN INTENSITY..
.OTHERWISE IT IS JUST LIKE A TRANSFORMER..
I'm agree fully to that above.
Try to explain the principle to your picture step by step.
NIBs or not or FIGUERA or not I don't care.
If you're principle produces overunity it's just fine to me.
Regards Arne
Sam6
Forest
The circuit produces a 16 step sine wave. The equations for the resistor values used to produce that waveform are shown on the schematic I posted on page 289. The sine wave is filtered to produce a smoothed waveform which is fed to an inverting op amp and a non inverting op amp to produce two waves 180 degrees out of phase. You can view the scope pictures of the unfiltered 180 degree shifted waveforms in the project description I posted on page 289.
The sinusoidal waveforms are applied to PWM chips which alter the duty cycles of constant amplitude pulses in a sinusoidal fashion at 25 KHz. Those pulses drive MOSFETs which switch constant voltage from a main power supply applied to the exciter coils. So the answer to your question is "yes and No", depending where you look at the waveform. But the effect is complementary sinusoidal power applied to the exciter coils in very short pulses. 8)
Sam6
NRamaswami
Having already done these experiments at 50 Hz AC using soft iron core I will try to do another experiment in the coming weeks using pretty much smaller table top sized devices and using permanent magnet core and about 840 hz.
I believe that Figuera used NS-NS-NS combination only but the primary and middle cores are permanent magnets and that the resistor array was used to increase the voltage of primary. From experience I know that higher the voltage of primary higher is the voltage of secondary. Higher the secondary voltage higher is the current from secondary. The mistake done by me is to use soft iron core rather than permanent magnet core. It should be essentially a Magnetic amplifier effect combined with a high voltage primary coil to oscillate the primary permanent magnets. The rotary coil was used by Figuera to oscillate DC input.  I think we can try to do a very small device and check if it would work.
This is my personal belief and assumptions only at the moment and I will post results of experiments and our observations after we test. Only very small device will be tested to avoid costs and labour and I will update after we do it. We intend to use MOSFETs to do the oscillation part. We will check if high frequency and high voltage combination can also be used using appropriate transistors. We need to wait and see.
Rather than 7 or 8 modules used by Figuera we will test with only one module and if results are promising we will add more modules.
I think it can work but let us wait and see.
Ramaswami Natarajan
marathonman
OMG i can't stop laughing from the stupidity, the blind leading the blind. ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha, ha. ha, ha, ha, ha, ha, ha.
I believe that Figuera used ...... that is a dead give away people that this FOOL NEVER HAD DONE ANY RESEARCH WHAT SO EVER IN THE FIGUERA DEVICE.
Stupid fools, you deserve one another.
Stupidity at it's finest.
