0 Members and 62 Guests are viewing this topic.
marathonman
Self inductance is the ratio of magnetic field per the amount of current in a circuit so if you add loops that magnetically link to the circuit you are changing this ratio. if you have say 1 amp of current flowing trough a circuit and add another loop to that side of the circuit it changes the ratio and you will experience a current drop in the system on that side of the circuit.
since self inductance (self induced within the circuit) is the magnetic linking that opposes the original current flow so by adding or subtracting loops to that side of the circuit you are changing the magnetic flux to current ratio.
this is how Figuera changed the current in his primaries one up and the other down in complete unison changing the magnetic flux to current ratio as the brush rotates. if the brush stopped so would the self inductance thus the current to the primaries would become a steady flow since it is DC.
Figuera on the other hand figured out that if you have a rotating positive brush contact he could change the magnetic field to current ratio on a steady basis and use the storing and releasing of potential to his advantage. with the rising side of part G and the rising primaries you will indeed have a voltage drop (Physics Fact)  because they are storing into the magnetic field but at the same time the reducing side is releasing the reduced potential into the system (Physics Fact) to off set this voltage drop which is exactly proportional to each other minus some losses and that is where the secondary feed back comes into play to replace those losses and to give an amplification to the rising primaries.
L (Self Inductance) increases if you add another loop to the circuit which increases the magnetic flux to current ratio thus the opposition to the original current flow. the more loops you add to that side of the circuit increases this ratio which decreases the current flow and the opposite is also true as you decrease the amount of loops that magnetically link to the circuit the current will in fact increase in that side of the circuit. putting them together and separating them with North opposing fields will allow you to control the current flow in to different sets of primaries in complete unison. so as the brush rotates you are adding loops to one side of the circuit and subtracting loops from the other side of the circuit at the positive rotating brush in complete unison.
I sure hope you can understand what i am trying to convey to you as this is very important in the self sustaining process.
I am not seeking any recognition or 15 minutes of fame what so ever just trying to change Humanity as the currant path leads us to extinction as Corporate and Government greed is killing us off one by one.
Regards,
Marathonman
marathonman
if the loop is located next to another loop it will magnetically link to that circuit causing a current drop and when a iron core is added it magnifies that reverse magnetic field by many many time then on top of that using a closed loop controller it will have very little flux leakage.
so by the below graph the more loops you add to the circuit the more opposition to current flow and the less loops the less opposition to current flow as the brush rotates.
These are in fact (Physics facts) and can NOT be denied or disputed by ANYONE.
Regards,
Marathonman
forest
marathonman
With lots of respect Mr Forest, that would be your and everyone else misconception not mine.
it is a Physics fact with a steady DC current is applied to a coil over a core and the magnetic field is increased the current will in fact be reduced. this is the magnetic flux to current ratio and when the loops increase so does the resistance to current increase causing a current reduction.
this is something that is not taught in no college anywhere as all they teach is that an Inductor is a static device when in fact it can be brought to an active position in a circuit to control current flow. i have posted so much info on this part G it is ridiculous as to why everyone is still scratching their heads when all it takes is a simple test to prove it to your self.
when a moving positive brush contact moves across a coil the ratio of magnetic flux to current will in fact change according to the laws of induction set forth by Faraday and Lenz that state any change in a circuit whether it is the current or the circuit it's self an EMF will be produced and the EMF product will be opposing the original current flow.
with all those posts you have you should know this Mr Forest. I myself choose to not leave any stone unturned. maybe some time should be set aside to actually read and understand my posts instead of just disagreeing. I myself love to learn new things.
It would be nice if one of these days someone actually reads the posts or information presented.
Regards,
Marathonman
AlienGrey
Quote from: forest on July 09, 2018, 01:33:04 PM
But inductance Control change od current not current
really ? try adding another winding to it and passing DC trough it and see what happens !
AG
