marathonman
  For all that is dabbling with the Figuera device of thinking of dabbling. please remember the device has to be hooked up to a load in order for the device to work. when the primaries polarize the secondaries and current begins to flow a second field will form in the secondary to oppose the original polarization (Lenz Law). it is this opposing field that is pushed from side to side by the increasing electromagnet. with out this opposing field the Figuera device will NOT put out anything what so ever as the opposing field will not be present with no load.
this is how Figuera induces motion into the secondary which gives the illusion of motion to the electric field.
just like a standard generator there has to be motion through the electric field as it is stationary so either the field has to move or the secondary has to move.
in the standard generator the secondary is what is moving as in the Figuera device except with the Figuera device it is moving the opposing field across the electric field giving the appearance or the illusion of motion to the electric field thus inducing EMF.
Moving the massless, weightless field is much easier that a huge hunk of rotating iron with many lbs of copper wire attached to it. ;D
Regards,
Marathonman
marathonman
Quote from another forum,"It has occurred to me that you have actually deciphered Clemente's design!" :o ??? ::)
i haven't stop laughing for over an hour now as it took him 6 long years just to grasp part G let alone the whole device. ;D
the info presented on this side is well documented and backed by Physics plus more bench work and tests than you realize. one realization of one part of the device 6 years later is NOT a decipher of the design. :o
I am not being mean or judgemental  but he who cry's foul for 6 years did NOT decipher the Figuera device over night plain and simple.
it was already their in plain site by the original replicator deciphered by me to the public.
they would still be scratching their heads if not for the original replicator and myself. ;D ;D ;D
Regards,
Marathonman
marathonman
Working on another primary bobbin today as it is raining where i live. the end pieces are as flat as they can be. it is actually enjoyable making the bobbins.
Regards,
Marathonman
marathonman
Here is a drawing of what my part G is going to look like when i am finished with it.  the center section is for the bearing support to take all the pressure off of the motor shaft coupling. maybe at a later date i will change to the aluminum rod for looks.
Regards,
Marathonman
citfta
What does the wire going to the slip ring connect to?  And why do you have a commutator for the top brushes?  Since your inductor is stationary you should only need two slip rings.  One for each of the rotating brushes.
You keep making personal attacks against me even though I have already publicly apologized for not understanding what you have been trying to say about the part G.  But it appears I may still understand it better than you do.  I have already shown how to make a simple part G and it only has taken me a few hours to make it instead of 6 years.
Carroll
