0 Members and 23 Guests are viewing this topic.
IMIGHTKNOW
A little self promotion right  ;D
As I have read from postings from Sparky Sweet he claims once the generator is at running conditions the exciting side of the generator drops to just the ohmic losses of the exciting coils with pressure circulating enough to maintain the load. Very interesting read to say the least.
It is not dragging or cogging  a slang word as to say but an attraction and repulsion from the stator to rotor as it spins because of the inherent properties of the secondary being induced.. ie the Lenz Law. Most people do not know a generator feed back to the exciting side at the rate of 10 to 15 % which is quite amazing considering the output in the high multi-kilowatts.
The Lenz Law can never be entirely nullified but yes it seems Figuera side stepped it on this one  ;D
Are you building?
kolbacict
tell me remind me please ,here in forum was somehow member,who posted his project in which was the same device.  I can't do find it at all.  I had to draw myself.
And what did this person mean by this device of his?
floodrod
Questions-   How important are the big spring-like coils for resistance?  What are the specs?
I assume reactance is in play here and standard resistors are a no-go?  What's the working principle?
Would those high wattage standard wire wound resistors work?  Or should they be like slinky springs?
What resistance value is the right range between connection points?
All the info I read skips over technicalities on the resistors..
Thanks in advanced
kolbacict
I generally suggested for a long time to remove the limiters, and rotate the usual variable resistor in a circle. Rotate with a motor. It's stupid to use a separate set of resistors and a separate mechanical switch. Maybe at that time there were no other options ...
floodrod
Perhaps an important piece of info that many overlook..
"We will add also a rotating brush which is always touching more than one contact."
~~~  buforn-1914_num_57955.pdf
I believe this means we can never let the field collapse.  Moreover, if we follow it word for word, it is "always touching more than one contact"..
On my electronic model, I was collapsing the field, causing induction steps..  Obviously this defeats the purpose.
These small details are probably very important
