0 Members and 46 Guests are viewing this topic.
floodrod
Next question:
Notice how all the electromagnet drawings either show no core /  or partial core?  No drawings show cores going fully through the electromagnets.  Seems like the depicted cores only interface with 1 pole of the electromagnet.
Can we assume we do NOT want the 2 unused poles of the electromagnets to have a good magnetic path between them?
Cadman
Floodrod, assume nothing. Figuera and Buforn patents show both ways.
Regarding Hanon's research,
If you pay attention to what Hanon presents at his web site, he is correct about the same polarity opposing. What is not correct is the depiction of the exciters fluctuating from minimum to maximum. We all fell for this, even though the patent warned us the drawing was only an example for the principle.
Think about it. Hanon's drawings show the two fields moving left to right alternating from Max to Min and backs it up with the video showing the better results with opposing magnets.
But the video uses movement of the coil which negates the patent claims.
In the video the strength of the magnets at each end never varies. That's the important take away, the exciter fields must not diminish in strength. Reducing one field will not keep the magnetic compression between the exciter fields. You have to keep the strength and compression while moving the exciter fields relative to the induced to duplicate the results in Hanon's video.
IMIGHTKNOW
Quote from: Cadman on March 27, 2023, 09:14:03 AM
You have a contradiction from one sentence to another.  "What is not correct is the depiction of the exciters fluctuating from minimum to maximum" then you go on to say "the two fields moving left to right alternating from Max to Min."
It is the same thing, two electromagnets are compressing the magnetic field lines then sweeping back and forth. This is done by raising and lowering both at the same time which is still a minimum to maximum of each electromagnet opposite yet in unison.
PS. The bar in the middle looks like some kind of reinforcement of some kind as it looks to be on top of the cores. The core will have a lot of force on them during the switching which mean they will need to be secured in some way.
Any thoughts?
madddann
Quote from: Cadman on March 27, 2023, 12:57:37 PM
This is what I mean
Hi all.
Nice idea Cadman, did you try it out yet? Maybe compare hanon's version vs yours...
Finally a path forward, THX.
Dann
