floodrod
Request to Math Wizards...
Can someone help me calculate the resistor values to achieve the wave in the image as designed?  I have spent dozens and dozens of hours calculating different values over and over and can not get the pattern right for the life of me..  Maybe it's not possible??
Goal-  2 sinewaves exactly 180 degrees out of phase perfectly equal..  Crossing at the exact middle..
I am currently getting the waves equal by using 2 separate resistor rigs..  But I want to see if it is possible to form 2 exact waves that cross in the exact middle as the patent is drawn..
rakarskiy
I worked with such controllers, but my controller turned out to be the most optimal for a single coil. In this case, the power of the resistors after the midpoint is very large.
The second voltage is not an indicator: the first indicator is the current strength, and the second is the magnetic induction in the core. It is on the creation of the linearity of magnetic induction that you need to focus. The calculation will be very COMPLEX.
floodrod
Did the guy with the red pen who corrected the water-damaged drawing mess everyone up?
Check Buforn's patent..  He is feeding the electromagnets negative return back to the positive brush.
No patents have any mention of a "battery" input source.  There is no way Buforn's drawings will work Unless the output coil is also the input to get it going..
Is it possible-  AC is fed to the pickup coil at first to induce the 2 outer electromagnets to flow current.  Then the commutator is taking the induced electromagnet currents and manipulating it so the 2 outer electromagnets become self-excited.  Then the power source can be removed and the input coil now becomes the output coil?
onepower
floodrod
QuoteCheck Buforn's patent..  He is feeding the electromagnets negative return back to the positive brush.
Good work, you seem to be the only one paying attention.
In the Figuera patent you posted he claims the source battery can be removed once the device is in operation. That is, the (-) and (+) terminals are not required as a constant input. At which point what we see in the picture is what we get as a self-operating stand alone circuit. This is common and many FE devices only require a small input which is later removed. It's crazy isn't it?, it's in plain sight in the patent but many can only see what they want to see.
Figuera
QuoteFrom this current is derived a small part to excite the machine
converting it in self-exciting and to operate the small motor which moves the
brush and the switch; the external current supply, this is the feeding current,
is removed and the machine continue working without any help indefinitely.
There is another aspect of the patent almost everyone missed.
Quoteand "+" and "-" the excitatory current which is taken from an external and foreigner generator.
In fact, this is a common theme among most past FE inventors who called what we know as man made AC/DC as false or foreign currents. It would take forever to explain all the details but we could think of it this way. We never see large AC/DC currents in nature unless a threshold has been exceeded and something discharges like lightning. Large man made currents (battery, AC, DC generators) were called false or foreign currents not generally found in nature and considered un-natural because they are.
Many FE inventors considered most of what mankind does as un-natural or foreign. They thought most men were brainwashed by society to all think and act the same following the often misguided laws of man instead of nature. This is why most men find this technology impossible and they don't have the capacity to think for themselves. So these inventors had a completely different mindset and a different way of looking at things.
For example, we could plant a single seed and decades later a large forest could be there. It is not man made, we had little or no part in it, we do not have the capacity to do such things only nature can. How can one tiny seed start a chain reaction causing massive amounts of material and energy to be concentrated in one area?. This concept is similar to how FE devices work, we cannot overpower nature only plant the seed (a small input) and let nature do the rest.
AC
floodrod
Another ominous clue may be the square with the circle on the parallel connection..  No other parallel connections on the patent have that symbol..
Back in that time, Tesla drew the square with 2 circles to represent AC.    Being that this is a parallel connection with one circle, Good possibility this is the point where the Electromagnet current was converted to DC (via The Switch) before it went to the brush.
" From this current is derived a small part to excite the machine converting it in self-exciting and to operate the small motor which moves the brush and the switch; the external current supply, this is the feeding current, is removed and the machine continue working without any help indefinitely."
