alan
Quote from: ramset on May 04, 2023, 10:51:41 AM
Alan
Here all the longtime researchers from your YouTube links
Are now open sourcing
And sharing the many reasons why they started a new forum
https://www.beyondunity.org/thread/public-answer-to-chris/
Respectfully
Chet
Ps
Alan
You have been dropping crumbs for years here ,
Do you have an experiment ( actual gain mechanism?) to support your assertions ?
Open source is the only path forward...
Too many years of .....
Do you believe OU is possible?
I trust Chris despite the negativity.    https://youtu.be/J9pjQOSkEuk
His POC closely resembles Figuera.
Cadman
Quote from: floodrod on May 04, 2023, 11:38:37 AM
I have since succeeded in causing the Back-EMF to be high enough to flow back to the Positive input lead and flow current back to the source using 2 coil positive biased 180 shifted waves. Theoretically it should now be possible (with the right coil setup and frequency parameters) to transfer inducted power that we pull into Back-EMF and send it back to the input to feed the circuit.
I don't know about all the cutting / linking / compression, etc.  This setup is simulating reciprocation of 2 magnets of the same polarity (repelling) on each side of a coil. If both magnets move at the exact same time and speed, induction only occurs if 1 is approaching and 1 is going away.   Otherwise it bucks and no induction.
My goal is to use the pickup coil's field to push the emptying coil past the zero line into the full other polarity.
Hi Floodrod,
If you don't mind saying, what are your cores made of?
ramset
Repost from alan's post above
Quote from: ramset on May 04, 2023, 04:51:41 PM
Alan
Respectfully
Chet
Ps
Alan
  Alan reply,
Quote "Do you believe OU is possible?
His POC closely resembles Figuera."
End quote
Chet Response to allan ,
"Alan
I believe we swim in a sea of energy
At an atomic level
I also believe in Open source and the transparency
That goes hand in hand .
Claims need this to advance !
Is this an open source claim ?( 35 watts more out than in ?)
Are persons allowed to share for replication?
Respectfully
Chet K
Ps
Apologies to Floodrod for interrupting ( although it does seem that many contributions from alan have been specifically addressed to Floodrod recently...
Thanks Grandma
floodrod
Thanks SL..  Any data is always appreciated.
Cadman-  Cores are salvaged laminated iron from old chokes.
Ramset- No worries, ain't my thread.  300+ pages in this thread from many years.  I have no right to hijack it.  I will continue my updates in the other thread I started.  Leave this thread as a place where everyone can discuss.
Any theories I come up with and post will be bench tested and results shared.  (good or bad)..
SolarLab
Floodrod,
Ran a couple of schemes this weekend but did not see anything outstanding.
Just a first pass analysis however, so we shall see. Won't try to post any data.
Much more to be done; so there are a lot more scenerios to look at.
SL
