0 Members and 42 Guests are viewing this topic.
kEhYo77
Alrightythen...
I have found a simple way to do the coil driving with Arduino!
All you need is:
1. ONE 10k/100k Ohm potentiometer. Connect the middle leg to Arduino's "A0" analog input. The other two legs of the pot goes to +5V and GND on Arduino.
2. TWO Logic Level MOSFET transistors to do the switching (Logic level - like in IRL series -  means that a mosfet is in a conduction saturation state at just +5V put to its gate). Connect the Gate of one mosfet to "Pin 3" and the others' gate to "Pin 11". Sources go to the "GND" of the Arduino board.
3. Connect +(positive) from a battery to both "North" & "South" coils and their ends to both drains in the two mosfets and -(negative) to the Arduino's "GND" close to the Source legs of mosfets.
4. Connect fast shottky diodes across each coil to do the freewheeling of current.
Program description:
Arduino is generating a digital signal at 32 kHz frequency using 2 PWM outputs. The value for each "sample" is taken from the sine table. There are 256 values of resolution for the "shape" of the sine wave and 256 values of amplitude. You can change phase shift by changing "offset" variable. Potentiometer allows to set the analog frequency from 0 to 1023 Hz at 1 Hz resolution...
NOW copy the code below to Arduino IDE window and save it to the microconroller and HERE YOU GO! ;)
/* CLEMENTE FIGUERAS GENERADOR DRIVER
* modification by kEhYo77
* Thanks must be given to Martin Nawrath for the developement of the original code to generate a sine wave using PWM and a LPF.
* http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/
#include "avr/pgmspace.h" //Store data in flash (program) memory instead of SRAM
// Look Up table of a single sine period divied up into 256 values. Refer to PWM to sine.xls on how the values was calculated
PROGMEM  prog_uchar sine256[]  = {
  127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,
  242,243,244,245,247,248,249,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,
  221,219,217,215,212,210,208,205,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,87,84,81,78,
  76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,
  33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit)) //define a bit to have the properties of a clear bit operator
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))//define a bit to have the properties of a set bit operator
int PWM1 = 11; //PWM1 output, phase 1
int PWM2 = 3; //PWM2 ouput, phase 2
int offset = 127; //offset is 180 degrees out of phase with the other phase
double dfreq;
const double refclk=31376.6;      // measured output frequency
int apin0 = 10;
// variables used inside interrupt service declared as voilatile
volatile byte current_count;              // Keep track of where the current count is in sine 256 array
volatile unsigned long phase_accumulator;   // pahse accumulator
volatile unsigned long tword_m;  // dds tuning word m, refer to DDS_calculator (from Martin Nawrath) for explination.
void setup()
  pinMode(PWM1, OUTPUT);      //sets the digital pin as output
  pinMode(PWM2, OUTPUT);      //sets the digital pin as output
  Setup_timer2();
  //Disable Timer 1 interrupt to avoid any timing delays
  cbi (TIMSK0,TOIE0);              //disable Timer0 !!! delay() is now not available
  sbi (TIMSK2,TOIE2);              //enable Timer2 Interrupt
  dfreq=10.0;                    //initial output frequency = 1000.o Hz
  tword_m=pow(2,32)*dfreq/refclk;  //calulate DDS new tuning word
  // running analog pot input with high speed clock (set prescale to 16)
  bitClear(ADCSRA,ADPS0);
  bitClear(ADCSRA,ADPS1);
  bitSet(ADCSRA,ADPS2);
void loop()
        apin0=analogRead(0);             //Read voltage on analog 1 to see desired output frequency, 0V = 0Hz, 5V = 1.023kHz
        if(dfreq != apin0){
          tword_m=pow(2,32)*dfreq/refclk;  //Calulate DDS new tuning word
          dfreq=apin0;
//Timer 2 setup
//Set prscaler to 1, PWM mode to phase correct PWM,  16000000/510 = 31372.55 Hz clock
void Setup_timer2()
  // Timer2 Clock Prescaler to : 1
  sbi (TCCR2B, CS20);
  cbi (TCCR2B, CS21);
  cbi (TCCR2B, CS22);
  // Timer2 PWM Mode set to Phase Correct PWM
  cbi (TCCR2A, COM2A0);  // clear Compare Match
  sbi (TCCR2A, COM2A1);
  cbi (TCCR2A, COM2B0);
  sbi (TCCR2A, COM2B1);
  // Mode 1  / Phase Correct PWM
  sbi (TCCR2B, WGM20);
  cbi (TCCR2B, WGM21);
  cbi (TCCR2B, WGM22);
//Timer2 Interrupt Service at 31372,550 KHz = 32uSec
//This is the timebase REFCLOCK for the DDS generator
//FOUT = (M (REFCLK)) / (2 exp 32)
//Runtime : 8 microseconds
ISR(TIMER2_OVF_vect)
  phase_accumulator=phase_accumulator+tword_m; //Adds tuning M word to previoud phase accumulator. refer to DDS_calculator (from Martin Nawrath) for explination.
  current_count=phase_accumulator >> 24;     // use upper 8 bits of phase_accumulator as frequency information
  OCR2A = pgm_read_byte_near(sine256 + current_count); // read value fron ROM sine table and send to PWM
  OCR2B = pgm_read_byte_near(sine256 + (uint8_t)(current_count + offset)); // read value fron ROM sine table and send to PWM, 180 Degree out of phase of PWM1
http://www.youtube.com/watch?v=hC70s3tYaGs&hd=1
bajac
Thanks KEhYo for the information. I will use test it and see how it works.
hanon
Hi all,
I am pretty sure that with a magnetic amplifier (saturable reactor) we can get the two opposite signals needed for the Figuera´s 1908 patent. For example: with a magnetic amplifier an audio amplifier (push-pull) may be implemented.
Idea: use a rectified AC signal as input to a magnetic amplifier in order to regulate the output signal with negative feedback, (negative gain) so that an increase in the input will make a decrease in the output (see attached sketch)
Some important facts about mag amp:
"The magnetic amplifier, like the vacuum tube and the transistor, is an electrical control valve where a smaller current controls another circuit´s larger current"
"With a magnetic amplifier you can control AC load current only. For DC applications it is possible to control an AC current and rectify the output"
"Magnetic amplifer control circuits should accept AC input signals as well as DC input signals. The DC input signal is called "bias". The most effective way to apply bias to a saturable core and also allow AC input signals to control the magnetic amplifier is to use a bias winding"
I attach an schematic to clarify this idea. The schematic is just to show the main idea. It is not a working design because I am not an expert (maybe someone more skillfull into mag amps may design a working device...). The main advantage is that this will be a very easy implementation. Any expert around here?
http://maybaummagnetics.files.wordpress.com/2010/01/68-71-27-2.pdf
http://avstop.com/ac/apgeneral/magneticamplifiers.html
http://electronics.stackexchange.com/questions/33587/controlling-a-current-with-another-home-made-alternatives-to-the-transistor
http://www.tpub.com/neets/book8/32o.htm
http://www.rfcafe.com/references/popular-electronics/magnetic-amplifiers-jul-1960-popular-electronics.htm
http://www.tuks.nl/pdf/Reference_Material/Magnetic_Amplifiers/
bajac
Ok, Guys,
I was getting something like 16V at the secondary and more power going in than going out. Does that mean that Figuera's device does not work? Not necessarily! I need to increase the secondary power output. How do I do that? One thing is for sure, 300 turns in the secondary is too low. Even though it is not stated in the patent, it is clear to me that this device requires a lot of turns to make it work. A lot of turns in the primary and secondary coils.
I will increase the secondary power by increasing the number of turns to increase the voltage. THIS DEVICES WILL NEVER SATURATE THE IRON CORE BECAUSE OF THE HIGH RELUCTANCE OF THE AIR GAPS! So do not be afraid to add turns to this device.
I am in the process of making a secondary coil with about 1,000 turns. I will let you know the results.
Bajac
bajac
The reason why the power output is increased by just adding turns to the secondary is because there is no relation between the input and output currents, that is, there are no effects of the Lenz's law.
In standards transformers, adding turns to the secondary coil would decrease the output current to maintain the I_primary/I_secondary current ratio of these transformers. And, if the secondary current is increased, so will the primary. This is no the case for the Figuera's devices.
