floodrod
floodrod
Quote from: onepower on May 17, 2023, 11:11:40 AM
I also included another picture of a 3D printed former you may recognize from figuera's patents. I packed the former with iron filings and a binder then glued a lid on. It works well and the core is comparable to transformer cores in it's response. Winding coils on the former was fun but no more difficult than a toroid.
AC
Hi AC,
Please expand on this.  This patent basically appears to describe electromagnets powered by alternating currents placed real close together.  Then between them is placed something like pancake pickup coils.  I say pancake because they must be thin to fit in the close gaps.
What were your results?
Am I correct to assume this differs from a standard transformer because of the 2nd electromagnet of opposite sign on each side?  I know from lots of tests that if I clamp two opposite sign electromagnets together, the driving current goes WAY down (depending on frequency).  Can you explain the dynamics of this build to us?
Thanks
Cadman
Quote from: floodrod on May 18, 2023, 03:58:48 PM
https://www.youtube.com/watch?v=es4zSnx07rk
Output sucks as expected.  But first glance at what it does..
Hi floodrod,
I don't want you to waste your time but that setup is backwards from the way Hanon's experiment was set up. There should be two reciprocating coils, one at each end with a single induced in between. Your commutator is make before break, isn't it?
https://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg575785/#msg575785
Also to duplicate the Buforn setup takes at least 3 cores as shown in his patent drawings. And with just 3 coils and straight cores in a row like Buforn's, one complete coil is not effective (the outer halves of the end coils).
But again, don't spend your time on it just for my account.
floodrod
Quote from: Cadman on May 19, 2023, 07:39:42 AM
Hi floodrod,
The brush is definitely larger than 1 contact.  But 11 contacts per half revolution is a lot of coils.  And I can't double them up as it is an uneven number.
I will be doing more experimenting tho.
floodrod
One thing is constant on all my builds.  Output always SUCKS..  There is a reason he used 7 or 8 sets of the triple-coils..  I don't think 1 coil set will do it...  But I continue to search for the configuration where adding several coil sets would be fruitful.
