0 Members and 66 Guests are viewing this topic.
a.king21
Quote from: bajac on January 17, 2014, 07:41:52 AM
The reason why the power output is increased by just adding turns to the secondary is because there is no relation between the input and output currents, that is, there is no effects of the Lenz's law.
In standards transformers, adding turns to the secondary coil would decrease the output current to maintain the current ratio of these transformers. And, if the secondary current is increased, so will the primary. This is no the case for the Figuera's devices.
Noted.
Also at the time the fashion was for high turns secondary. It was an accepted fact because  the interrupter was a common feature of most coils. Sometimes the interrupter is not even mentioned, and I was wondering about Figuera in that light.
hanon
Quote from: a.king21 on January 17, 2014, 08:52:38 AM
Noted.
Hi,
Which interrupter? Could you clarify that idea? A picture or link will be nice to see it
a.king21
Interrupter is a make/break switch (usually electromagnetic) designed for DC transformer
operation. Think how an old electric bell works. So it is effectively a RADIANT ENERGY DEVICE!!!!
Doug1
Bajac
  In order for the device to be able to function at some point without adding more current from the batteries or source there has to be a method to loop the current from the load back into the inducer coils and in doing so there will be less of it after the load has consumed what it needs. The potential will be lower between the load and the return path compared to the leading direction of current to the load.Potential drops,higher in the beginning lower at the end. Which is hard for anyone to argue regardless of type of current dc or ac.
   The inducers manifest a magnetic field between which the induced will reside.
The circuit of the induced does not show a wire connection back to the source or to the inducers.Unless I am mistaken.
    So the magnetic field must be conserved once established by movement of the field within the core/s and regenerative even after load consumption.You can refer to magnetic reminence in a self exiting generator where the left over magnetic field is used to increase the rotor field strength on the start up of the gen. The field in rotation is induced into the stator the current from there is used to further power up the rotor enough to hold a stable output.
  The strength of the field produced by the inducers must be greater then the field in the consuming circuit. Adding more turns to a conductor (mag wire) increases resistance with length of wire being longer in order for it to make more turns. Unless,,,,, you use more conductors and combine them only on the ends there by increasing the turns without increasing the resistance. With a little creativity of compounding some of the conductors some of the current used to establish the field by the source may be stored within the core to produce the same effect as a rectifier.Instead of blocking current it would be blocking the propagation of the magnetic field reflected back from the induced circuit and forcing it to re enter the coil/s in the same direction as the source would to complete the loop magnetically.
As to turns count ,before the holidays I had come up with 2008 T per inducer with 56 strands 200.66 ft of wire for my use.Keeping conductor length at that which has very little resistance per strand. The resistors are supposed to handle the steering of the currents into the inducers with out wasting power. If the path to one of the inducers is an easier path then through the resisters it will follow to the inducer intended.They to will have to be compared to and match the load circuit and resistance of it in terms of reluctance set up in the induced coil to prevent the induced coil from dominating the inducers. For the purpose of testing, lights would work well as resisters with varied sizes and wattage's. The object being no lights should actually light up if the current is going mostly to one of the desired inducers avioding the path of resistance. If a light or number of lights were to become lit it would indicate there is too much reluctance against the inducers and the load is too large for size of the electro magnets making up the inducers.
  No you may not have a picture.
that-prophet
yes, you loop the cureent
with pulleys of different sizes
you can not only loop it
but you can multiply it
with sinple pulleys
free energy is so simple
that we have overlooked it
Free energy has been discovered = (this is a Gift from God)
http://free-energy.yolasite.com/
I call this free energy machine a GEM = (God s Electricity Multiplier)
This Christian Warrior was shown this Miracle by the God of our Holy Bible
-   from The God of the Bible = (Father +Jesus +Holy Spirit)
When you take a careful look at this technology
-   It seems obvious (the more generators you add, the greater the multiplication factor)
-   -   You put power into a motor with a large pulley
-   -   -   Which you only have to turn the one single turn (very little energy)
Then you take power out of the one to a hundred small pulleys with generators
-   That you attach to the same belt
-   -   Each generator rotates tens to hundreds of times faster
-   -   -   Each rotation gives you electricity (lots of energy)
-   -   -   -   It is truly that simple
