0 Members and 56 Guests are viewing this topic.
NoMoreSlave
Hi Arto,
I like your drawings!
but i dont see the looping back.
did you made that commutator/potis?
Thanks!
NMS
Artoj
Thanks NMS
I find most patent drawings misleading and sometimes incorrect. This is usually done so it is hard to copy, I redraw the patent so it is a step closer to engineering reality, which means I could build it and test the patent holders assertions about validity. I have been able to discover a lot about the nature of the deception or about the underlying designs, any which way is a step closer to knowing how something is supposed to work. I try to make it easier for others to find their answers, regards Arto.
Farmhand
Quote from: NoMoreSlave on February 11, 2014, 03:03:24 PM
Hallo,
is Figuera a Lenz killer by 90 degrees?
Please make some +&- operation and share your opinion.
Hi Farmhand,
nice to see your post.
IMO, the switch you mentioned  is a commutator (the second one controlled by the motor, witch not appears in the patents, because it was a common method), it has the function of converting the AC to DC.
like the one you find in the DC motors but it is used in reveres mode, the brushes rotate to get DC from the statistic output coil for the self-looping.
Regards,
NMS
EDIT: Actually the drawing does show the device is permanently looped, I think, my bad. Except for the one position it is shown in ?
If we turn the commutator one position, then the current loop goes from the commutator to the north coils then from the north coils to the south coils then back to the commutator and through the resistors back to where we started from.
Cheers
P.S What do you mean by the 90 degrees thing ?
Quoteis Figuera a Lenz killer by 90 degrees?
Do you mean 90 degrees phase difference between voltage and current at the output ?
Farmhand
I think it needs to tried exactly how it is drawn ! Even if only with one set of coils, three coils, one north, one south and one induced. A resistor board a commutator and a battery to start it.
Maybe a good idea to use a separate battery just to run the commutator so as to keep it at a constant speed. I don't think there is any need to worry about the power the commutator consumes. I think that can be overlooked for now.
If I am the first one to make it work do I get a let off on the hat eating.  ;D
