NRamaswami
Regarding the silly claim part.. I suggest that you take a small transformer. Place copper sheets and plastic sheets beneath it and cover it on sides with copper sheets and then plastic sheets. Insulate it except for the input and output wires.. See if the transformer works and produces current in the secondary.. Why call me silly when you have done the experiment..
Power is not energy, voltage is not energy, current is not energy.
Generators work just fine in total vacuums. Wrapping a transformer completely in copper won't prevent it from working. You've made several statements that are simply total BS. "Self-sustaining" around here means that you can remove _all_ input sources of _energy_ and the device continues to operate. The Amplidyne is not self-sustaining and does not produce more ENERGY output than input. Neither does any device from Figuera. Neither does any device you can demonstrate.
Please stop posting utter fictions and distortions of reality. Please stop pretending to "teach" what you yourself do not know. If you make a claim, like your "generators don't work unless they have access to the atmosphere", that contradicts what we all know, then you really should provide some evidence that supports your claims. But of course you cannot.
Quote from: NRamaswami on February 15, 2014, 07:57:33 AM
I have transformers all around me that are completely encased in metal and plastic and they work just fine. Would you like to see photographs of them? This "experiment" is performed millions of times every day, by all the sealed, completely encased transformers in the world.  I challenge YOU to provide proof of this claim. Let's see your "experiment" where you do as you say. There is absolutely no empirical or theoretical support for your claim... so YOU are the one who needs to do the experiment and show your results so that they can be examined to find your ERROR.
Further, let's see you demonstrate your claim about generators and the atmosphere. That should be loads of fun. I'm sure NASA will be distressed to hear that their spacecraft power plants, waaaaay out there in space distant from all atmospheres, cannot generate electricity.
NRamaswami
1. I'm not teaching any thing for I have made it clear that I'm not an Electrical Engineer.
2. What I have posted are results obtained and that can be verified and can be replicated by any one.
3. I do concede that I have not tested the self sustaining part. There is nothing to hide. The output voltage and amperage is very high and cannot be done without help from a trained Electrical Engineer. Safety first for me.
4. Space ships use only solar arrays and Nuclear materials based thermionic batteries. They can easily carry a powerful alternator..Why don't they do it?
Results that I stated are verifiable and replicatable by any one..Do the experiment and then shout me down..if the results are not there.
NRamaswami
You mix things up..
I said Transformers covered with copper sheets all around. Then plastic sheets placed on copper sheets.
All transformers are made up of magnetising metals. Without iron transformers would not work. When transformers are covered by copper plates in the way I described they do not work. Your statement is transformers covered with metals. All transformers we see are covered with metals to dissipate heat but they are not copper but magnetisable metals.  My statement is non magnetic copper sheet covered by non magnetic non metallic plastic. Please post pictures of transformers fully covered with copper working fine..
In my experiments I have found that if we make the magnet very powerful current simply refuses to go to load. If the magnet is very powerful it simply eats the electricity given to it. I suggest that you wind a quadfilar coil around plastic tube of 4 inch diameter and wrap on that another plastic sheet and iron rods and then continue the winding in this fashion and after about 18 layers complete the quadfilar winding. Try to send the current through the quadfilar winding to a load and see if the load is able to get any power..
Zero.
Powerful magnet simply eats current given to it. I do not know why it happens. This is a result you can replicate easily.
I do not intend to teach any thing to any one. I'm just sharing the results of my experiments. Nothing more. If I have not done any thing, there is truthful admission that I'm yet to do it..I suggest that you replicate the experiments and then tell me please..
