0 Members and 68 Guests are viewing this topic.
NRamaswami
No disappointments really and I appreciate your kind words very much. I can see that you want the measurement to be perfect and that is perectly desirable and understandable.
Thanks to the efforts of Hanon we have the old spanish patents and I have translated them. Even before that we have ignored whatever is stated in textbooks and went by our experimental results. For example the High voltage is needed to induce a high induced emf is never stated in any book. We needed to test that and understand that. Prior to that we used to give 12 volts and 16 amps current from a step down transformer without any success in generating power in the secondary. It was all a slow learning curve. If we look at the magnetic field stength of a magnet it only talks about ampere turns. Strangely a weak magnet produces better output in secondary and a strong magnet does not do that. We found this minimum 20:1 voltage:amperage combination by experiments.
I apologize for any miscommunication on my part. I thank you very much for your very kind words and cautious approach in using the right technique and measuring instruments for measurements.
Regarding Hubbard, it still remains mysterious to me. He is reported to have used mimimum number of layers which may not be true. But the output is very high amperage and lower voltage when it was given to load and so a higher voltage must be present at no load conditions. But that is still not resolved by me. I can understand the Figuera concept clearly and am reasonably confident that I can come up with working results.
I remain grateful and I remain obliged.
forest
NRamaswami
Reading all your comments makes me feel like Alice in Wonderland, so extraordinary it is.Imho Figuera invented somethind which perpetuate in history for a long time. Hubbard device should be the same , maybe without iron core powered by Tesla coil ?
I feel that the mystery maybe about the way magnetic induction is used , did you allow magnetic field collapse to zero or maintain it constantly above zero strength when changing ?
Good luck and please keep going !
NRamaswami
Hi Forest..
Thanks for the kind words..
regarding the fact whether the magnetic field was collapsing or not, How do I know? I do not know..All I know is this..
If the magnetic field strength of both the coils is the same we get the best results..If one primary is weaker than the other the results are not useful at all. Both of them must be of equal strength.
I determined the magnetic field strength by the number of turns of the primary and kept both of them constant. Since the input is AC and is coming from the same source, there was no need for the rotary device and since the current moved from NS of P1 to NS of P2 there was no need for any resistor array.. I ignored them all. No capacitors were used either. They were simply a waste of input..Only without capacitors and with just wires we got the best results. No complicated circuit nothing. No electronics.. Simply it s massive number of iron rods running to perhaps about 150 kg and a lot of wires and nothing more than that.  All wires wound in the same direction.. That is all is needed to replicate the experiment. You need a lot of turns and a lot of wire. One thing that might have made all this possible is the quadfilar coil as current circulates four times in the first primary before it goes to the second primary. And the middle secondary is of equal length but has a lot more turns than the primary as it is a single wire and has many layers of wires.
Any one can easily replicate the experiment. And see the results. But be extremely careful the voltage and amperage output is high.
Iron used was soft iron rods. Nothing else..
gyulasun
By any chance, did you or your mates take any photograps of that setup you had?  OR you still have some 'remains' and could take a photo?
Thanks,  Gyula
NRamaswami
Oh Yes.. I have all the wires remaining and can take pictures and post right away.. I have removed the quadfilar wire and wound them in to different things and last week we were trying to understand the Hubbard core.. We have succeeded in creating magnetism in all the 8 coils..Just wait..Just took them as they are in my mini lab room in the office and am posting them for you.
The quadfilar coil has been removed to do other experiments. I bought 8 to 12 coils of 4 sq mm wires and we manually fixed them to become as quadfilar coil to cut costs. The one you see on the Hubbard attempt is the only three core cable we have. We have a total of about 1300 meters of wire but that is needed to make one module of Figuera and we would need another 1300 meters to make the second module.
The problem can be solved easily if I make the second module a step down transformer of sorts and then provide the feedback from the second module secondary to the first module primary. But I need to invest time, money, manpower etc and note that all is my personal time and money.
You now have the photos. We can take videos and show the actual results also but it would require another few man days of work and I need to hire people and pay them all. That is a problem and getting the right people to do the work is also a problem..But I will do it any way..
