0 Members and 84 Guests are viewing this topic.
Marsing
Quote from: NRamaswami on February 17, 2014, 03:03:13 AM
We have connected ammeters and voltmeters properly. But NewtonII could be correct in his statements for we had many Ammeters burn out and we avoided that problem by having fuzes to the primary input to control the current and I can tell you we have probably lost about 100 fuses. ................
thanks Gyula, i hope that NRamaswami use that setup for his device.
One more question NRamaswami,
can you say the rate of fuses ? ie 5A or 10A
I will wait your result in a week or two.
thanks...
NRamaswami
We have used fuses from 2 amps to 15 amps. Current fuse is 15 amps and it stays intact as the primary current has never been in excess of 10 amps. Secondary no fuse..But I'm not going to post back any replies as it takes a lot of my time. Bye until next week.
NRamaswami
I saw one post from Newton II: Transformerw would not work with Pulsed DC. totally wrong.
Transformers work with Pulsed DC. Full sign wave pulsed DC would make transformers work. Some how the efficiency is lower than AC. That is all.
We are testing methods of windings that reduces the impedance loss. Possibly we need to lacquar the iron rods once to reduce heat loss as hysterisis. But that is expensive for me. With ineffficient methods, the device produced at least as accepted here 630 volts. I know that when the secondary produces 250 volts at no load the voltage at load is 120 volts and 2 amps and when the secondary produces 240 volts at no load the useful power is 100 volts and 1.8 amps. As the voltage in the secondary increases, the vibratons of the core increases and this must lead to higher output. But let us test and then see the results.
I will try to create a smaller version of the device by the end of this week.  Thanks to you all and Bye for now.
hanon
Quote from: NRamaswami on February 16, 2014, 02:34:18 PM
describes in one line for using a secondary under the primary to get industrial scale currents. ...
...Possibly all of you have focused only on the drawings and have not studied the patent description of the original and missed the line.
Patent No. 30378 (year 1902) literally states:
"The current dynamos, come from groups of Clarke machines, and our generator recalls, in its fundamental principle, the Ruhmkorff induction coil.  ...
...As much as we take, as a starting point, the fundamental principle that supports the construction of the Ruhmkorff induction coil, our generator is not a cluster of these coils from which differs completely. ...
...the motionless induced circuit placed within the magnetic fields of the excitatory electromagnets."
Figuera mentioned the Ruhmkorff coil twice for some reason...   Maybe now we can guess why he did it.
Thank you NRamaswami for de-encrypting the patent !!!
bajac
The following link shows the setup for the driver I am using in the 1908 device. See this photo for setup #1:
https://imageshack.com/i/euodzpj
The waveform corresponds to a load of two 50 Ohms/100W resistors instead of the primary coils. I am using seven rheostats each rated 20 Ohms/25W. This is an improvement with respect to fixed power resistors for avoiding re-soldering, every time a different resistor value is needed.
I ran an experiment to observe how critical is the matching of the values of the seven resistors and the reactance of the primary coils. I started with each rheostat having a value of 7 Ohms, which produced an output voltage of about 14 Vac. See this photo for setup #3:
https://imageshack.com/i/0nt3urj
The output increased to about 19Vac when the rheostats were changed to 12 Ohms. See this photo for setup #4:
https://imageshack.com/i/5b39cej
And finally, the output increased to about 25 Vac when the rheostats were changed to 20 Ohms. See this photo for setup #5:
https://imageshack.com/i/nfa8y0j
Another adjustment that was made based on the interpretation of the patent description about keeping the cores in contact but not in communication. I made the cores touch each other but without having electrical continuity. I used an Ohmmeter and measured open circuit between the three iron cores. That is, I have a minimum air gap of about the thickness of the insulating coating of the silicone steel sheets. I also verified that there was not cross-talking between the two primary coils. See the oscilloscope's graphs in this photo:
https://imageshack.com/i/7gr8yrj
I HAVE NOT YET TESTED OVERUNITY! I want to optimize the electrical parameters, first.
