0 Members and 62 Guests are viewing this topic.
bajac
@Lightend
No testing yet. I just finished putting together the seven sets of coils. See my progress of the INFINITE ENERGY TOWER here:
http://imageshack.us/photo/my-images/197/figueratower66.JPG/
Bajac
hanon
Hi all,
Here I attach a pdf file with Figuera´s patent from 1902 about the electrical generator "Generador Figuera-Blasberg". This patent was filed by Figuera some days before the telegram where he stated that the patent was sold to a banker union with a sale deed. After filing this patent and signing the patent sale there was a big silence until 1908 when Mr. Figuera filed his final patent with a detailed description of his invention on the 31th of October of 1908. In November of 1908 Clemente Figuera died. I don´t know the cause of the death neither the exact date, just that it occurred in November for some mentions in the newspapers. I think for myself that maybe Figuera was very ill and he decided to file his last patent as a legacy before dying.  Clemente Figuera was born in 1845.
As you can see in the patent drawing there is no reference to the reddish ink mentioned in the text. Therefore, in the 1902 patent it was not included the position of the induced coil. This patent was not granted because it seems that, after filing it and after the patent sale deed, no one paid the annuity renewal, which confirms the intention of hiding the patent, as occurred in fact.
kEhYo77
@bajac
Its taking shape now :) Nice setup, I like it.
But what about those thick reinforcing aluminium? bars on the sides of cores?
Eddy currents inside those will be huge!
Unless they are there as phase shifters...
bajac
Keyho,
The permeability of aluminum is about the same as air. Because the aluminum is not in the path of the magnetic field, I see not reason for the magnetic field to leave the main core (high permeability) and travel through the aluminum (very low permeability). It could be very small interaction at the air gaps where fringing effects should occur. But, this is an issue that I will pay attention during experimentation.
Hanon,
Thank you for the superb work that you have done related to Mr. Figuera. It really gives a historical credibility to his work.
Thanks,
Bajac
kEhYo77
@bajac
You do not seem to understand how magnetic field operate.
It is about Electric vector A potential, a stress gradient. Aligned atoms inside the core make a strong density potential whereas free air outside is of lower flux density.
anything in the path between those two areas will be influenced by this gradient with the inverse square law when it comes to distance away from the core.
You will heat those bars due to eddy currents, even if you would isolate them from the cores with a dielectric (to exclude heat transfer from the cores).
