Magnets/Buoyancy
Started by KSW, April 13, 2005, 01:37:06 PM
DarkLight
Yes but this work is done by gravity. We don' t need  to put in any external energy. The center of mass of the heavy plate goes down due to the gravity force.
When the mass center goes down we use gravity to do that. Whet it goes up - we need to put in external energy to overcome the grawity force.
DarkLight
with my construction. Why did you draw that?
jaybird
Please have a look here for physics involved...or not involved.
http://www.lhup.edu/~dsimanek/museum/themes/buoyant.htm
I am not sure if this will work.
But, I am open to why it would!? ;D
Quoted from Bottom of page:
QuoteAll of these illustrate that geometry is the underlying reason why overbalanced wheels will not work. You may indeed get a boost from the imbalance of mass, but in a cyclic process that mass must be moved back to where it started to repeat the cycle, and that's where you lose what you gained.
Now, if you could use GEOMETRY FOR you, instead of AGAINST...or a combo of magnets and the wheel (perhaps a picture of how the magnets are used)...
DarkLight
Free Energy, I think that my scheme is clear enough. Direction of rotation is exactly the oposite of that you draw! Big volume goes up, small volume goes down. In my scheme the energy that is needed to close elements is minimal, in yours - it is not. That is very important because if this energy is too much, the motor will not work.
FreeEnergy
