Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
4Tesla
Hi Plengo,
I'm doing crystal power cell research and haven't been able to keep the cells going without using soluble crystal materials which absorb moisture from the air.  Are you using soluble materials?  Are you sealing in moisture?
If you can't answer because it might reveal your secrets, that is okay.
Thanks,
4Tesla
plengo
Quote from: 4Tesla on August 31, 2014, 03:13:48 AM
Hi Plengo,
Thanks,
4Tesla
Solutions that absorb water is your best and worst enemy. The crystal structure NEEDS water to grow and I think the crystal is the generator of the energy with the plates only being a catalyst providing the voltage differential.
Now, if you lock the AIR OUT, you will be able to minimize corrosion extensively.
Fausto.
plengo
Quote from: jbignes5 on August 30, 2014, 11:00:05 PM
Yeah I found that after the growth time for the crystals that there was little galvanic action as well but my cell never went past the begining stages. I went to the oscillator to experiment with to run from the cell and never really picked it back up. My version used not so active materials like aluminum and graphite. Not in the right proportions either. You have to balance the masses in my version to retain the materials.
The aluminum wire was heated and sprayed with borax, this formed a dry foam like coating. Then I baked it till it was golden brown. This creates a base crystal structure and when you put the aluminum wire into the crystal bath of alum borax and potassium it solidifies into a nice crystal structure that gets very clear and shinny on the aluminum. Once I let it set I start using the oscillator more and more to build a proper energy flow.
One mistake I made was to make the gap between the center graphite and the aluminum wire coil was too big and alot of crystal had to be formed and took way over a month to solidify fully. Using a smaller gap would decrease the solidity phase and increase the capacitance. My version came out to a volt but seem to get stronger current wise as the crystal formed, not in voltage but current capability.
The formula also included Epsom salts to give it pure water to form the other crystals with. No tap water was used on the recipe but I parboiled the glass jar I made the cell in and I assume the steam helped hydrate the mix a bit. I want to try the magnesium graphite or copper unit to see if it still works but magnesium is protected differently.
One interesting thing I found out about using graphite is that the crystals started growing into the graphite and that increases the surface area of the graphite. This could be the reason for the growth but I'll have to look into that more when I get back to experimenting with the cells again.
I hope everything goes well this time with the gogo plan Plengo. Having product to give out will only help the cause and might work really well to get the product out there and in the hands of the public. Word of mouth is the best seller of all.
Would be able to make a video of your cell? It seams very interesting your process.
Fausto.
4Tesla
Quote from: plengo on August 31, 2014, 07:14:19 PM
Fausto.
Thanks Fausto!
You have a working sealed crystal cell?  If so, that is very good news!
plengo
Quote from: 4Tesla on August 31, 2014, 08:57:43 PM
Thanks Fausto!
YES, YES and YES. She is a beauty. Not strong but enough for in the night bother you.
It is VERY TRICKY to make the resin work correctly. I don't know why YET but I am testing how to get there correctly.
I will make a video soon showing this ONE cell working so well. I am actually a little uncomfortable to show her because it is not much light, but believe me, she is running very, very well.
Sometimes things happened by chance and I was lucky to get that one right at first because many tries are not working.
BUT I am learning something very important, it is necessary to let the cell's crystal structure to grow first, stop the initial corrosion and only then seal it.
Fausto.
