Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
plengo
Thank you Allwest,
it does sound very right. My cells under a very low resistance load (probably in the orders of 1 ohm or less) is also showing around that low mili-voltage and that current.
Fausto.
Allwest
Plengo,
You really should   try
Heat on copper and cold on mag, with the size of your last crystal cell, you probably have a 2 amp cell
I think the heat is acting on the cell in two ways, thermal electric generator and piezoelectric vibration generator
Neither one of these is a galvanic reaction, if the cell stays dry
On another idea on forming the crystals
I am thinking of an idea to try, possibly an alignment of  the crystals, possibly more power
Form the crystals within the cell with heat on copper side and cold on the mag, it may cause the crystals to form positive and negative
Just some ideas for  the cause
Best of luck
plengo
Allwest,
excellent idea. I will try that.
Fausto.
Allwest
Plengo,
With some research another possible reason for heat affecting these crystal cells
http://en.wikipedia.org/wiki/Pyroelectricity
Maybe its time to try some tourmaline in the mix
Best of luck
Allwest
Plengo,
Happy new years
How goes the battle?
Best of luck
