Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
plengo
Quote from: NickZ on October 15, 2014, 10:39:05 PM
  Plengo:
  If you don't want to show what you've got, but want us to chart dissolving cells, as a base line to compare to what you haven't shown yet, well, I don't share your mode of operation.
  I recommend that you just make a video of your cells, like you've done before, and let us decide if what you have made now is of interest, or not. Some guys may take you up on your "base line" tests. But, I have other things on my plate.
  I trust and believe in what you've shown us previously, and don't need to chart decaying cells to prove the point.
                                                              NickZ
Ok Nick here it goes:
get the following items mix them , grid them and let them dry to almost zero humitidy:
- sand
- epson salts
- rochelle salts
- activated carbon
- sodium meta silica pentahydrate
- alum
Figure whatever proportion you want for the needs that you want, very easy, just play with it until you get what you think is working the most.
Make the plates sizes, put the mix with water in between the plates and run it.
Very simple, no need for a video.
Fausto.
plengo
Question to ALL:
Is it possible to have a battery with BOTH ELECTRODE METALS being the SAME METAL and produce constant output power?
For example positive is Aluminium and negative being Aluminium.
Fausto.
Billynjamie
IbPointless did some experiments on that very subject. In the very earlie days at the energeticfourm. I believe if you check his YouTube he still has the vids on his channel. Nothing outstanding but he has a few vids and some posts about it on the bedini crystal battery thread. It would probably take a while to find those posts though.
profitis
Yes its very possible to use two same electrodes in both a galvanic setup and also catalytic spillover setup.in the galvanic setup one aluminum piece is less exposed to oxidizer(air) than the other aluminum piece.in another situation one aluminum piece is attacked more quicker than the other due to porosity and surface area leading to massive eddy current hysterisis giving a galvanic potential.with nonreactive electrodes (eg.platinum) you can get spillover effect from different exposure to air or h2.spillover effect does not consume inert catalyst electrode material
profitis
