Thanks to ALL for your help!!
Mr.Clean's Device
Started by verpies, November 09, 2012, 03:37:25 PM
Groundloop
Quote from: poynt99 on November 12, 2012, 08:59:27 PM
Thanks verpies, nice work.
The bottom (? ? ?) must go to the circuit ground. If the 9V supply is derived from the 12V supply (and I suspect it is), then the upper (? ? ?) would go to the 9V regulator input in the PWM block. Kurt does show both going to that block.
Hopefully Kurt will be a little more forthcoming with some answers, then we may know for certain if what I am saying is correct.
.99,
He is running the oscillator from a 9 Volt battery.
The battery can be seen in this video: http://www.youtube.com/watch?v=gHnJYl6q96w&feature=relmfu
Attached is my understanding of his circuit.
[EDIT] I have updated my circuit drawing according to the hand drawing from Mr. Clean.
GL.
verpies
Quote from: TinselKoala on November 12, 2012, 08:28:22 PM
The "unconnected parallel wire"... is that half of a pair with the other, connected wire, like lampcord or coax or twisted pair, or is it a separate lead altogether? It would be nice to have the dimensions of this wire, how far apart it is from the other wire, how long, how is it laid out?
I really don't know.
All I have is that hand drawn drawing from Mr. Clean that shows the wire from the negative terminal of C7 capacitor being parallel to the wire from a positive terminal of this capacitor.
The free wire appears to be tuning/detuning something.  It  resembles another successful OU Device that worked when it was tuned/detuned by a free hanging wire (or touched by hand).  See this video of it.
verpies
Quote from: Groundloop on November 13, 2012, 01:57:11 AM
Mr. Clean has not admitted to the separate 9V battery powering the PWM oscillator circuit however a 9V battery is visible on his 39E video but this is not the video of the self-runner.
Also, the value of R5 was my interpretation and has not been confirmed by the author.
Also, the position of R7 on your schematic diagram is inconsistent with with this drawing from the author.
Finally, the author has not confirmed whether the +12V supply rail (e.g. collector of Q1) is connected to the positive terminal of C7.
Groundloop
Quote from: verpies on November 13, 2012, 06:42:23 AM
The position of R7 is inconsistent with this drawing from the author.
Verpies,
But it sure looks like the 1 Ohm resistor is at the end of the + lead in the video?
Or is the red clip the + wire?
GL.
Groundloop
Quote from: mrclean on November 11, 2012, 02:00:20 AM
oh man this made me laugh out loud :D no im not using any tricks, but im not having much luck replicating this myself, so i hope not to cause too much frustration, but here is how i have it wired...
http://img802.imageshack.us/img802/1874/imagedmb.jpg[/size]
Mr. Clean,
Do you run your oscillator circuit from a 9 Volt battery?
What is the value on the resistor connected to the base of transistor BFY51?
Is your 3 Watt LED lamp a 12 Volt lamp?
GL.
