Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
AbbaRue
The steel strapping I was pursuing didn't go well, they only sell it in 100lb rolls.
I bought some toroidal transformers 120/240V inputs.
8.5V 1.1A   and  14.9V 0.53A  outputs.
And there is still over an inch opening left in the center
I bought these at the surplus store in London On. for $5 each.
I will use these for my first tests.
I got some nice caps.
I bought 2 electrolytic caps  2.8 Farads each at 20-25 volts.
Connected in series they will give me  1.4 Farads at 40 volts.
I plan a charging them at about 30 volts.
I also bought 10 electrolytics  16,000 micro farads at 60 volts
Connected in parallel they will give me 160,000 micro farads at 60 volts.
I plan on trying these out first at about 40 volts.
Anyone planing on using Feynman's HV cap. idea may want to try making there own.
using 2 sheets of aluminum foil and 2 sheets of wax paper much wider then the foil.
Then just roll them up. Try using about 2 meters at a time then connect them in parallel to get higher cap.
Anything longer then 2 meters will be hard to roll up and keep things straight.
And these will be real cheap to make.
I suggest this because 3kv caps at 10uf could be hard to find.
tao
Quote from: AbbaRue on May 11, 2008, 02:52:33 AM
Has anyone had contact with J. Naudin recently?
It would be interesting if he would join us on this thread for some input.
I kind of wonder why he didn't pursue this device further?
By now he might have had a working power source.
I asked Naudin once why he doesn't fully 'finish' a lot of his experiments, meaning, taking them the full course. I also asked his intentions on ever actually wanting to release full plans for an FE device, etc, etc....
His response was basically that he doesn't want to do that, he wants the viewer/reader to take those needed final steps (theorizing, concluding, building, etc.) to reach their own FE devices. He told me that the reason a lot of his testing and researches seem unfinished or not concluded at times is because his sole goal was only ever to TEST all these various claims of these various inventors/devices.
The reason I decided to let you all know this is, don't think that because Naudin 'seemed' to stop testing or developing any given idea on his website, that it is in any way worthless.
sulake
My "practise" setup :D
Here is my VSG setup. The MOSFET switch is good but caps are too small capacity (2x 25000MFD)...
Why do americans (made in U.S.A.) use marking "MFD"? I suppose it is 25000uF (micro farads)?
My carbon rod is not good either, it is from 1,5V D size battery. Carbon rod has suck'd in the electrolyte from the battery.
Allso, the largest size Thorium loaded Tungsten electrode off the shelf was only 3.2mm diameter, it has 2% Thorium in it.
MOSFET switch has 5x RFP50N05 mosfets
www.datasheetcatalog.org/datasheets/50/346845_DS.pdf -Mosfet Datasheet
I can not find those carbon rods here (Finland). Allso ordering from U.S.A. is not a good option because of the expensive tariff.
Germany could be one source to EU folks, no tariff to those orders, maybe PESE could find those and add a link to the shop?
Earl
AbbaRue,
in my opinion, the last person in the entire world that we need at OU.com is JLN.  He has a highly censored email list and both I and Harti were kicked off it.  He could have admitted his measurement errors with the MEG, but he didn't.  By not admitting his errors, he gave the FE movement a knife in the back.  I have great suspicions about his true agenda.
Quote from: tao on May 11, 2008, 11:04:37 AM
Tao,  in my opinion it is JLN that is worthless; the only positive thing he has ever done is to have banned Harti from his censored email list, which lead to the formation of OU.com.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
All,
looking very carefully at the equipment cabinet with the toroids in it that Tesla_2006 said contained the carbon and tungsten rods, I see absolutely no signs of anything internal to the toroids with the exception of an L bracket on the bottom holding a bolt that is fixed on the top plate with a nut.  This appears to me to be a superficially impressive photo, but in reality the photo has nothing to do with power generation from nuclear reactions:  no carbon rods, no connections, no nothing.  The photo could be part of bla bla bla.
Earl
