Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
hartiberlin
Hmm,
in the interview he said, that they are using the aluminium tube ?
or just aluminiumplates ?
for the conversion of the high voltage to lower 18 Volts voltage
and high amperage,instead of the MeV from the Beta-particles.
So probably the Beta Electrons are just braked down in speed while hitting
the aluminiumOxid and converted to free flowing electrons inside the Alumnium.
The question is, how you are going to connect to the Aluminium to which
other pole, so you could draw a current from it ?
Is it versus the circuit ground ?or just earth ground ?
Is the placement of the magnets right ?
zerotensor
Quote from: Feynman on May 19, 2008, 01:10:11 AM
Synergetic Energy Teleconference mp3 -  Part I
http://www.mediafire.com/?gftwmp9zw9x
Wow!
more, please :)
Do you have a link to part 2?
Where did you find this??
aleks
Quote from: aleks on May 19, 2008, 04:01:55 AMI was also thinking that graphite rods can be stacked together to form a graphite pack (with height roughly equal to diameter of this pack). You may then put this pack inside a factory-made multi-winding toroidal transformer.
Well, since modifications are turned off... I would like to add that toroid may have a magnetic core that will supply the required B-field inside the toroid that will permeate the graphite rod pack. It will then look like toroid on that 60kW generator picture.
Koen1
Wow I'm off for a couple of days and all kinds of stuff happening here! :D
Interesting stuff... Can someone give me a quick recap on why exactly we're
talking about using an aluminium tube?
Quote from: aleksIs it really fusion? Looks like melting, not necessarily fusion. Photo can't say what it really is.
Well aleks, what does fusion look like then eh? ;) Either like plasma or like a mushroom cloud?
What does beta decay "look like" according to you?
As far as I know it doesn't "look like" anything, it's just a piece of beta emitting material, and you can only
"see" that when you put your geiger counter next to it... Since the Vall?e Protelf is basically a method
of stimulating artificial beta emissions, I don't really expect the material to look extremely different afterward.
Or had you expected a blue glowing blob? ;) ;D
starcruiser
From what I am gathering thus far is the aluminum is used for shielding the reaction chamber to contain any "radiation" from the carbon rod excitation. It was also mentioned that aluminum could or should be used for the electrode connections to the carbon rod that provides the voltage/current pulses. Initial design considerations;
1. A solenoid type of pick up coil is used for tapping/collecting the output. the size of the wire for the solenoid is up for debate/determination. i.e. how heavy of a wire is required due to the current generating capability and how many turns to capture the Beta particle emisions. question still would remain whether multiple coils arranged over or around the carbon pile (rod(s) would provide more output.
2. Aluminum shielding for the reaction chamber to contain any harmful emissions to you or the control electronics (can blow out electronics in the immediate area (see above post by Uncle Fester).
3. Looping the output to the input after initiating the conversion process can cause a runaway condition thus a control circuit is required to limit the feedback and control the process.
4. It was mentioned about using a PWM to control the process (this is still open for debate and design for the best way to do it).
5. Heating issue with the carbon rod, how can this be controlled or excess heat dissapated? possibly using soft copper tubing for the collector and passing water through it and using that with a radiator of a sort as a heat exchanger (my idea).
6. using a transformer on the output to step down voltage and hence step up the current (if needed).
7. A static B-Field is used to activate the conversion process (or organize it), neo magnet is used for this, magnetic field strength directly affects conversion and output.
8. Voltage/current discharged thru the Carbon affects output, this can be the control point (may need to be) to control the generator action.
9. For capacitor charging a 35khz (or so) PWM could be used to control cap charging and a IGBJT switch for discharge of the caps thru the carbon rod(s). By using this method we can control the voltage output to say 120vac/220vac for mains compatibility. a thought.
10. Use a fixed frequency oscillator (60hz/50hz) to trigger the IGBJT control circuit to produce mains compatible AC output. Use this circuit to disengage the charging circuit (above in #9) when discharge occurs to avoid potential damage to the charging circuit. may require a IGBJT or other similar device due to voltage current. The oscillator disconnect may not be required due to feedback but may be needed for a saftey cut off.
We need to replicate the simple version with limited run time and over voltage and over heating cut offs for testing the above. Lets all get this going and share any circuit ideas and drawings to get a sample unit designed and then take it to the next steps i.e. incorporating heating control (might make a good house heater??) :)
This is indeed exciting times guys!
Regards,
Carl
