Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
aleks
Quote from: Feynman on May 03, 2008, 01:25:26 PMSo far, Dr. Vall?e's theory is consistent with the experiments, and has been able to make accurate predictions.
What kind of predictions? Prediction that it produces overunity energy? I do not really see how spark gap technologies can be 'predicted' - they are extremely hard to control, measure and plan. I'm not calling DC acoustic waves a theory for the same reason. It is a working hypothesis. Theory should not only give qualitative results (i.e. presence of beta radiation, some traces of transmutation, overunity, etc), but they should give quantitative estimation, required modes of operation - both electrical and mechanical (carbon rod quality, etc). And what the hell is 8kW per gram? Is carbon consumed or what?
Note the structure of carbon rods:
Those crystals should slap each other real hard when electric pulse goes through them.
Feynman
Seriously man, go do your homework!  I can't believe the comments you are making without even bothering to read the research.
QuoteWhat kind of predictions?
The very prediction you are talking about!  For instance, the 8kW per gram is a QUANTITATIVE PREDICTION that comes from an estimation done by Lacheze-Murel, translated by Naudin.  The carbon is not consumed because the half life of the Boron-12 isotope is 20ms, which quickly decays back into regular Carbon after releasing beta electrons.
QuoteIn the case of carbon, for example , with a coefficient of effectiveness of 10^-5, (1 atom out of every 100,000 entering into reaction), and a total output of 20%, the reconstitution of carbon from Boron-12 would provide 8kW per gram of carbon used.
-JLN
http://jlnlabs.online.fr/vsg/synergetic.htm
Are you missing the entire point here? For several hundred dollars in parts, we can BUILD devices which produce massive amounts of output energy relative to the input.   I don't see why you still are sitting here skeptically armchair theorizing.
AbbaRue
Device #1 brings some thoughts to my mind as well.
The cold fusion reactors using tungsten in baking soda for one.
I don't think anyone tried placing a toroidal coil around the reaction chamber yet.
Also thought of the Correas'  Abnormal discharge tube filled with argon.
I don't think they placed a toroidal coil around the argon tubes either.
This device is easy to build using the carbon core from carbon flashlight batteries.
The tungsten rods are available at the local welding supply store.
The hard part is winding the toroidal coils.
But I was wondering why the tungsten rod is needed, couldn't you just use 2 carbon rods?
starcruiser
Regards,
Carl
hydrocontrol
Interesting idea using gases and a B-field.. I remember reading an article years ago about a nobel gas engine and this discussion made my mind click. I did a Google search and found this :
The Mystery and Legacy of Joseph Papp's Noble Gas Engine
http://www.infinite-energy.com/iemagazine/issue51/papp.html
Also the Dr. Stiffler circuit uses a neon bulb..
Hummmm... Makes you wonder... Maybe using a gas is possible..
