Thanks to ALL for your help!!
kapacitiv Transformer
Started by sergirafael, November 21, 2012, 05:37:47 PM
sergirafael
The cylindrical coil and the cylindrical capacitor, the electric magnetic wave can be used in a device as a standing wave of a resonance circuit in koheränt serial switch again. The length of the solenoid must be 1/8, and the length of the cylinder Landa capacitor must be 1/8 Landa. By Maxwell the electric field in the capacitor and the magnetic field in the coil in the amplitude level is enhanced. The two components are wound onto a Ferit or magnetic tubes.
sergirafael
a stupid video of narow manufacture and devloped 200kHz resonance coil on HP Tonercartuche mangetic tubes
http://youtu.be/mqqi6AcUHrY
http://youtu.be/_YpptEuZL7I
to first run use handsperds
http://youtu.be/9IPe2N8PpXI
Paul-R
Where is Stefan when he is really needed?
sergirafael
I DONT NOW
so yep sorry my terrible english i write
Testen Sie einen neuen Browser mit automatischer Übersetzungsfunktion.Chrome herunterladenSchließen
Übersetzer
Production of long coils and capacitive transformer
Magnetizable ferrite in the length of 30 cm and a diameter of 1 cm are to pull it aufzu a copper wire . The ferrite contained in old Tonercartouchen are cheap and geeiegnet from Mass. .
The ferrite rod is can a Doppelkleband ( Teppichkleband ) umwicklet , then the copper wire are wound. For this, the ferrite rod is clamped into a battery drilling machine . Low speed of the copper wire can be manually raised . For this purpose, the winder should wear gloves to avoid sore .
Thus, several layers of enamelled copper wire wound over each other on a rod to make a long coil.
The capacitor and the coil in a . Between the coil layers Alluminiumfolien can be wound alternately. Household foil is suitable for it. Between each one Alluminiumfolie a plastic film must be wound mandatory. The thickness of the plastic film decides on the Durchrlschlagsfestigkeit . The thicker this plastic film the higher the Spannug be held between the plates Aluminium . An electrolytic paper with acetic acid can be decisive for the choice and increase the capacity.
The resonant frequency for a 1 mm ² copper wire on a 30cm long ferrite coil is around 200 kHz + / - 5kHz tolerance . This is nachzuvolziehen experimentally. For this purpose, an audio amplifier without treble band filter is fed by a frequency generator. The audio amplifier is to switch to one of the four windings. The amplitude should be kept as small as possible since high voltage is produced at the resonant frequency . A Osszilloskop then the amplitude at the resonant frequency to 200 kHz is a factor 2 to 5 times as large as in the remaining frequency range.
The capacitor plates should be wrapped lying parallel to the coils can be switched to that frequency . To this end, this capacitor must be precisely calculated at the resonant frequency formula .
If the long wire coil in series with the capacitors plates obtained a good voltage source with low internal resistance , you can switch this Paralell one obtains a power source.
Due to wind up a primary coil with fewer turns the Sekunär coil can now be controlled . This winding is best to switch in the middle of words between the secondary windings.
The suppressor circuit of a long- transformer
A longitudinal transformer must be operated in the resonance frequency. A switching power supply is very well suited to the primary coil to control . The resistance of the primary coil has to be not less than the resistance of the primary coil of the switching power supply. It now removes from the switching power supply transformer .
The primary coil is then soldered in place of the primary winding of the switched mode power supply between the drain of the transistor and the GND power resistor . The optocoupler can most easily be switched by a 200 mV germanium diode. The power supply should now tackten . The voltage at the long coil comes from 200kHz to high voltage.
Google Übersetzer für Unternehmen:Translator ToolkitWebsite-ÜbersetzerGlobal Market Finder
Sofortübersetzung deaktivierenÜber Google ÜbersetzerMobilDatenschutzHilfeFeedback geben
sergirafael
s the change of these two variables as a coupled alternating field or uncoupled waves as electromagnetic radio waves and even body waves in scalar quantities referring.
https://de.wikipedia.org/wiki/Energiedichte
Within the 1913 reconstructed works by Maxwell was eingentlich a coil condenser (as I accidentally as a capacitive transformer) drawn and described. Commercially available high-performance coils, the wires flat and not wrapped around, so this is a capacity within the element is formed. The higher the power density and the smaller the footprint have these two elements to be considered when changing fields of electromagnetic components higher.
To built a flexible Ferrite core
https://www.youtube.com/watch?v=oowUnncp3RY
As patterns in the picture Green a 4.7 micro farad capacitor which was subsequently ensnared with 45 turns of enamelled copper wire.
 Now an inductive alternating field in resonance frequency and a capacitive alternating field is within the Bauteis now switched the power density is improved as a choke or storage capacity by a factor of .5, within positive feedback improves innerhlab laboratory setups this factor.
How do self made a flexible long coil.
https://www.youtube.com/watch?v=w8Kxc7CrlZM
When the wave maxima of the alternating electric field enters into effect at the point of Wellenminium of tromagnetic alternating field, the coil would have to wound only at the ends of the capacitor.
Thus, the motor is so rotated by the effect of the electric field in the torque, but it is interesting that this was caused by a coil, so only Cosiunu Phi 1 was utilized.
Toroide whit a flexible mecanicel Tesla Coil
https://www.youtube.com/watch?v=gtpvZ2yKPXk
To simply the low-voltage range for measuring used is 63 volts AC drives so that coil-wound quartz crystal, the superjacent capacitor Platen which were wound around the spool start in very low frequency of 5200 to fall in love with the effect in voltage. This, however, only within the resonant frequency. The plates are not connected to the AC voltage, the poles are open. Image construction from 2010 onwards.
Kondensators Foil wired on a Coper coil
https://www.youtube.com/watch?v=bwZy3wI46LQ
Now the capacitor plate in series with the coil or Parallel with the coil can be driven, instead of the quartz-crystal ferrite, allows an extremely strong electrostatic field from the induction to generate. After Maxwell 2. conservation law gives an energy density which is greater than with conventional devices, which was also described mathematically measured technically and scientifically already 1929th.
https://www.youtube.com/watch?v=jLqBEkGImko
What is important here not to use capacitors which have a Alluminiumcase but Tandalkondensatoren which possess a high dielectric strength. The coil is wound on the Tandalkondensator, the coil capacitor is very suitable for an integral differential PID controller element, or for the final stage of Klass D amplifier unit, or for a very good resonance transformer. Next added a flat coil by 150 heart resonates goes.
