Lynx Joule Inverter
Started by Lynxsteam, November 29, 2012, 12:42:40 PM
synchro1
@Lakes,
         Totoalas is measuring the D.C. voltage output from the APM. The APM is using the A.C neutral line for an antenna, and the buried water pipe for the earth ground. The A.C. neutral line is bonded to a seperate earth ground as described above in the earth ground antenna exerpt from Wikipedia.
          Totoalas then has a socket wired in between these two lines in parallel with the APM into which he screws LED bulbs, and another socket wired to the D.C. output of the APM. He measures the D.C. output voltage from the APM with the bulbs in one then the other socket. There's no electrical power in the wires. The wires are bonded; One to a metel faucet  buried pipe earth ground, and the other to an earth grounded A.C. neutral line. The A.C. neutral line acts as an earth grounded RF recieving antenna. Powerfull Telluric currents from the earth run between these two grounds when the circuit's completed by connection. That's why Totoalas's rcd breaker trips when he joins these two wires. The breaker remains closed when the circuits, along with their isolating circuit resistance, are in position.
           You need to join these wires with an APM circuit in between , or the circuit in the base of a 5 watt 220 volt LED bulb to generate any electrical current. The wires alone will measure nothing!
totoalas
Using only ac neutral plus earth with 5 w 220 v ac lamp load
Output of lamp placed on top of a 10 w solar panel produced 2.62 v dc steady voltage
This is done without the APM circuit
Totoalas
Lakes
The Lamps are a bit expensive, but the circuit should be cheap to experiment with.
synchro1
I have a question to pose to the Overunity Group: How much power would two APM's generate in parallel between Totoalas's A.C. neutral line and his faucet ground? Half each, or double the amount? The results from this simple test could send Richter magnitude shock waves around the Planet!
@e2matrix,
             Totoalas already stated his APM is the same as Joe Tate's. Joe designed and was the first to patent and name it. Lake's is identical too.
e2matrix
Quote from: Lakes on December 28, 2012, 11:50:08 AM
Is the circuit diagram Lakes posted above the same basic diagram and component values you are using totoalas ?
