Lynx Joule Inverter
Started by Lynxsteam, November 29, 2012, 12:42:40 PM
totoalas
Hi synchro
thanks for the link
Hi Lynx
Im using House AC neutral  line....     with Neutral and Earth ground   I can lit up a 5 watt led 220 v ac lamp ( Neuground Lighting)
With your rf diode charger  ...  no need for earth ground   but charging very fast with my hands on the output ( short) and the reading goes to 100 v dc in aorund 40 seconds.....
The Neutral from the electric company as I know is also earthed   and the earth in our house closes the loop ( from my understanding)
I prefer Neutral when shorted with body ground easily charges the caps but in a pulse mode and discharge  for a split second to my 12 v dc  strip leds   7 meters in lenghth
As live and Neutral are side by side the possiblity is a short circuit which will trip the house circuit breaker
totoalas
synchro1
The A.C. neutral line runs from the house back to the power plant where it runs into the ground to complete the circuit. The Earth Ground can simply be a pipe in the ground. Output from the Ambient Power Module is directly proportional to the antenna size!
          "The amount of voltage and power will be determined by local radio noise levels and ANTENNA DIMENSIONS".
The antenna size of the A.C. neutral line is lazy eight! You have to step back and consider how awesome this breakthrough is!
An APM between the A.C. neutral ground and the Earth Ground at the power plant would recieve and rectify the same RF signal that just passes right through the wire as a full sine wave in the sub MHZ range. This power is not induced A.C. There's zero power comming from the A.C. neutral line. Most of the broadcast energy picked up by these wires comes from Outer Space, not the local radio broadcast stations. These wires would generate around the same amount of power if we shut the powerplant down and stopped the radio broadcasts. The reason the power increases at night is because the Sun's not blocking Cosmic Radiation in the RF range from the Galaxy!
totoalas
Quote from: synchro1 on December 23, 2012, 07:33:08 PM
The A.C. neutral line runs from the house back to the power plant. The Earth Ground can simply be a pipe in the ground. Output from the Ambient Power Module is directly proportioal to antenna size! The antenna size of the A.C. neutral line is lazy eight! You have to step back and consider how awesome this breakthrough is!
Thanks for the technical description  .. Yes  youre correct   I im touching the ground output and not short the circuit as I described before...
Now  Tech gurus    its your turn.......
totoalas
PARAV
Quote from: totoalas on December 23, 2012, 05:07:27 PM
Ive replicated Lynx RF diode charger by using ac neutral  as antenna  and it works
AC Neutral RF Charger 231212   Youtube  Imtotob
thanks to Lynx
totoalas :)
Hi Totoalas and Synchro,
I kind of missed something here in the translation -- so please correct me if I'm wrong.
Can you tell me what the "Lynx RF diode charger " is ?
Is it that Tate circuit modified some how?
Sorry for the confusion.-----Regards, Paul
totoalas
