TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
Zeitmaschine
Quote from: Hoppy on October 24, 2016, 08:06:35 AM
You are not allowed to escape the lunatic asylum.  :(
Yes! ............ or No?
Stepanov Transformer Replication
The three-phase choke and the three-phase capacitor is needed to spread the free energy collected by the high voltage transformer equally between the three phases. Essentially that means the connection method (which includes for sure a diode bridge) of the high voltage transformer is the only thing left to solve.
elementSix
  I am just reposting what S9 trolled away.
Ok I will try to make a video as soon as I can and will post it on here.  I have little time to do this and I need help.  So if your a radio electrical engineer, that's what I need.  The tour, the kappadze device  all get there energy from the atom of the copper coil with the help of the earths magnetic field and the electric field produced by  the Impulse wave from the primary circuit.  There are numerous ways to produce die-electricity.  So you can use many arrangments.  The technical term for this phenominon is efnmr.  That's earth field nuclear magnetic resonance.  But you can also create the homogeneous magnetic field artificially with a large uniform magnets.  Anyways you can use HF AC or LF AC.  DC voltages have the most profound effect.  But AC is the easiest to tune.  When using AC you have to have a primary impulse circuit that goes into a secondary that is directly connected to another primary. When you change the AC frequency in the first primary the impulses that go to the next primary circuit can easily be tuned to the harmonic resonance of that circuit.  Without harmonic resonance this generator will not work.  Don smith devices do not have the separate inductor circuits to work right.  You have to add another primary and secondary that are all resonant circuits.  They don't have to be in the same resonance as each other, but it wouldn't hurt.  There are many different ways of creating a solid state generator.  Tesla used may make and break devices from spark gaps to rotating commutators to create the impulse train.  There are rules that must be followed strictly for nmr to work.  First is a unidirectional energy flow in the making of the impulse wave. Ok I am making a video soon and will post it on here.  I have little time to do this and I need help.  So if your a radio electrical engineer, that's what I need.  The tour, the kappadze device  all get there energy from the atom of the copper coil with the help of the earths magnetic field and the electric field produced by  the Impulse wave from the primary circuit.  There are numerous ways to produce die-electricity.  So you can use many arrangments.  The technical term for this phenominon is efnmr.  That's earth field nuclear magnetic resonance.  But you can also create the homogeneous magnetic field artificially with a large uniform magnets.  Anyways you can use HF AC or LF AC.  DC voltages have the most profound effect.  But AC is the easiest to tune.  When using AC you have to have a primary impulse circuit that goes into a secondary that is directly connected to another primary. When you change the AC frequency in the first primary the impulses that go to the next primary circuit can easily be tuned to the harmonic resonance of that circuit.  Without harmonic resonance this generator will not work.  Don smith devices do not have the separate inductor circuits to work right.  You have to add another primary and secondary that are all resonant circuits.  They don't have to be in the same resonance as each other, but it wouldn't hurt.  There are many different ways of creating a solid state generator.  Tesla used may make and break devices from spark gaps to rotating commutators to create the impulse train.  There are rules that must be followed strictly for nmr to work.  First is a unidirectional energy flow in the making of the impulse wave. Ok I am making a video soon and will post it on here.  I have little time to do this and I need help.  So if your a radio electrical engineer, that's what I need.  The tour, the kappadze device  all get there energy from the atom of the copper coil with the help of the earths magnetic field and the electric field produced by  the Impulse wave from the primary circuit.  There are numerous ways to produce die-electricity.  So you can use many arrangments.  The technical term for this phenominon is efnmr.  That's earth field nuclear magnetic resonance.  But you can also create the homogeneous magnetic field artificially with a large uniform magnets.  Anyways you can use HF AC or LF AC.  DC voltages have the most profound effect.  But AC is the easiest to tune.  When using AC you have to have a primary impulse circuit that goes into a secondary that is directly connected to another primary. When you change the AC frequency in the first primary the impulses that go to the next primary circuit can easily be tuned to the harmonic resonance of that circuit.  Without harmonic resonance this generator will not work.  Don smith devices do not have the separate inductor circuits to work right.  You have to add another primary and secondary that are all resonant circuits.  They don't have to be in the same resonance as each other, but it wouldn't hurt.  There are many different ways of creating a solid state generator.  Tesla used may make and break devices from spark gaps to rotating commutators to create the impulse train.  There are rules that must be followed strictly for nmr to work.  First is a unidirectional energy flow in the making of the impulse wave.    Ok I am making a video soon and will post it on here.  I have little time to do this and I need help.  So if your a radio electrical engineer, that's what I need.  The tour, the kappadze device  all get there energy from the atom of the copper coil with the help of the earths magnetic field and the electric field produced by  the Impulse wave from the primary circuit.  There are numerous ways to produce die-electricity.  So you can use many arrangments.  The technical term for this phenominon is efnmr.  That's earth field nuclear magnetic resonance.  But you can also create the homogeneous magnetic field artificially with a large uniform magnets.  Anyways you can use HF AC or LF AC.  DC voltages have the most profound effect.  But AC is the easiest to tune.  When using AC you have to have a primary impulse circuit that goes into a secondary that is directly connected to another primary. When you change the AC frequency in the first primary the impulses that go to the next primary circuit can easily be tuned to the harmonic resonance of that circuit.  Without harmonic resonance this generator will not work.  Don smith devices do not have the separate inductor circuits to work right.  You have to add another primary and secondary that are all resonant circuits.  They don't have to be in the same resonance as each other, but it wouldn't hurt.  There are many different ways of creating a solid state generator.  Tesla used may make and break devices from spark gaps to rotating commutators to create the impulse train.  There are rules that must be followed strictly for nmr to work.  First is a unidirectional energy flow in the making of the impulse wave.     That's why DC is better for creating an impulse and using a magnetic spark gap too keep the energy flow in the primary going in one direction.  [/size]Another rule is impulse time and duration.  When setting up your impulse to fit harmonically with your tesla coils, the impulse must be timed to overlap the previous impulse that is bouncing back and fourth in the primary.  Kappanadze gave a good example a few years back.  If you had a group of solders stomping on a bridge and you wanted to use that vibratory wave to bring it down, you have all the solider a stomp right as the wave comes back and the new wave to match it as it passes.  By doing so you are adding the same small amount of energy to create a very large wave that will build up as large as the structure or in this case the circuit will allow.  That's harmonic resonance.  The next rule is the voltage.  Everyone with a teal coil wants to jam as much voltage as the system will allow.  But if they turned down the pressure and allow the impulse to find it's perfect pressure amount, you would be one step closer to producing dielectricity.  Now you say, that good an all but there Iano current worth a dam in my output.  Will one thing tesla left out of his patents was his second secondary coil that had the same induction as the first.  He put it in directly attached to the first secondary coil but a few feet away from any magnetic influence.  That was his current amplifier.  Now I haven't tried the don smith way of using a clockwise, counter clockwise secondary to produce current from one and voltage from the other. But like I said there are many ways of arranging these generators.Another rule is very little to NO CURRENT can be used or destroyed in the primary circuit.  If you have current being consumed past a very small amount it will be very hard for this to work.  Now Kappanadze found a great circuit that fixed a lot of tuning time.  He used a supply transformer with a control circuit from an lcd tv.  It used a PWM to change the transistor on off time to fit the impulse to the changing circuit.  A piezo electric generator that kept resonance in the secondary coil by changing the impulse in the primary. He may have also used a piezo generator in his red box setup.  You can here it tapping in the background, but it didn't last too long, cause it burned up by the end of the video.  He ran it into an ignition coil I believe.  But I have been outa this field for a few years so my memory isn't what it was.  I am bad at making how to videos but I will do my best.
  Now I can't find the picture at the moment, but it shows an AC waveform with what's called a tesla node on it.  It show the the node will move to the right spot by adding a small capacitor on the secondary in series to create a harmonic circuit. But I'll try to get it in the video.  Ok I will continue this another day, try to have patients and read tesla's work.  Remember that when you tune your coils and you don't have a circuit to keep automatic resonance, that your not just tuning. The RLC in the circuit. You are tuning it to the magnetic field in your area on Earth.    That's why you can't copy some one else's coil length and cap size.  It usually won't work. Things like a small coil with a movable iron rod inside and in series with the primary circuit to help tune.  Check out Tesla drawlings. Start old school and make a Tesla coil with an adjustable oil cap with parallel plates, home made of course and try nitrous filled spark arrestors and use multiple ones if it helps but if you use a spark gap, make it adjustable tungsten with magnetic quenching.  it helps a lot. If using HF AC, I would suggest parallel spark gaps to primary, right after cap.. What I'm saying is there's many ways to make a SSG.  Thanks e6
Zeitmaschine
Quote from: Zeitmaschine on November 06, 2016, 08:15:25 AM
»This video is no longer available because the YouTube account associated with this video has been terminated.«
Seems the user of that account went to madhouse already. :( :( :(
Sorry about that.
Quote from: elementSix on November 12, 2016, 01:12:50 AM
Studying that wall of text brings us closer to free energy? ???
elementSix
I'm sorry, I have no idea how that happened.  I didn't paste the same thing over and over again on purpose.
             Thanks e6
I'm trying my best zeitgeist. I hope so.    ???
