25mV Joule Thief powered by peltier merely using our body heat -Free energy 24/7
Started by magpwr, December 20, 2012, 09:26:33 AM
In my video, using the spindle bobbin I put 20 turns on a toroid in a couple of minutes, so you can do 100 turns in ten or fifteen minutes. How long is that?
omdano
Hello magpwr
i have built the whole circuit and it didnt work with a peltier ..
i tied to test it with a AA battery and it worked.. what do you think might be the problem in my case ?
(i didnt put the 100uf cause it said optional)
Edit : it worked but the led didnt look like it was producing any light , i will try to change the gate resistance
xee2
@ omdano
The Peltier may not produce enough current. Can you try circuit with a power supply? It probably takes a few mA to light the LED at 0.2 volts.
omdano
I added another peltier to produce more current so now its working fine :p thx
xee2
Quote from: omdano on March 11, 2014, 06:46:04 AM
:)  Congratulations. Can you post a video so others can see how you did it?
