1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
hartiberlin
Quote from: TinselKoala on January 06, 2013, 05:24:48 PM
I think the Joule heating of the coffeepot is the best output power measurement he's made so far. There is not much that can go wrong with the method the way he did it.
Yes, the test with the water hettle boiler was the most accurate and as this one and the light comparison test
showed underunity, the whole setup seems not to be overunity....
Too bad...but did you expect from just an aircore transformer with no external input via the environment ?
Maybe it could be brought to overunity mode, if the transmitter coil is wired to house ground
and the driver current , after going through the transmitter coil not being connected to the grid ground,
but only to a house ground or water pipe ?
Then the transmitter coil could suck in free electrons from the ground and the input current will
go down...
2. Also it would be interesting to see how iron wire for the bifilar output coil would work and also  it would
be interesting to see, if grounding the bulb loads to a water pipe will decrease the input currents for the transmitter coil.
So basically you will have then some Avramenko Plug design at work, so a one wire resonance system which
could suck in free electrons from the ground line...
Regards, Stefan.
dllabarre
Quote from: hartiberlin on January 07, 2013, 11:05:10 PM
Regards, Stefan.
I think the iron wire would heat up like a steel/iron pan on the stove top would heat.
crazycut06
go down...
Regards, Stefan.
Hi Stefan,
I asked romerouk if he had tried to use an earth ground with his setup, but he replied, there's no difference on output power.
hartiberlin
Quote from: dllabarre on January 07, 2013, 11:14:40 PM
Yes, but I guess how much would depend on the thickness on the wire...
Otherwise there is also stranded iron wire, something like this which is used
for 12 Volts halogen lighting where they put 2 wires besides each other in
parallel and hang these halogen spots between them.
These are stranded iron wires and come with an isolation plastic coating
around them.
Would be interesting to see, if they will also heat up too fast...
Regards, Stefan.
hartiberlin
Quote from: crazycut06 on January 08, 2013, 01:17:45 AM
Hi Stefan,
Yes, maybe not in output power, but what about the input power ?
Will it be lower then ?
