1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
tagor
Paul-R
Quote from: hartiberlin on January 08, 2013, 02:51:25 AM
These are stranded iron wires and come with an isolation plastic coating
Presumably you mean steel wires rather than iron wires.
vrand
JLN latest video on his very interesting Tesla Pancake energy device, this time adding a feedback coil for input to an inverter:
GEGENE : Closed Loop test Phase 2 with a Grid Tie Inverter
http://www.youtube.com/watch?v=-OlLRrTSvYU
Cheers
mikestocks2006
The next logical step would be to feed the Grid Tie Inverter instead of the halogen lamps, use the output from the GTI as input to the induction cooktop.
And use the smaller coil as "extra" power output? (lamps etc)?
Will it be a self-runner with power to spare?
Thanks for the video/link
Mike
Why oh why do people insist on using the "box label" on a device as the "output power" no matter "watt" ? If a light bulb says "500 Watts" on it, that does NOT mean that it will always dissipate 500 Watts !! This is its rated power dissipation when it is supplied with its rated voltage from a source capable of supplying the necessary current so that the voltage doesn't sag. Just because there are 1800 watts of bulbs connected to the circuit and glowing, that does not mean that the circuit is dissipating 1800 Watts !!
Jean-Louis surely knows this.
I am watching this thread and his videos with great amusement. The chances of self-looping are nil. The output power available is less than the input power and he's already confirmed this by two independent sets of measurements: the rough calorimetry, which could NOT be in error by enough to invalidate his results, and also the photometry of the light output.
