I have a working free energy device
Started by one_christian_warrior, January 05, 2013, 03:20:51 PM
FatBird
And the Instructions are soooo CLEAR & Easy to Understand.  LOL
that_prophet
FREE ENERGY HAS BEEN FOUND
http://free-energy.yolasite.com/
   Yes, that is correct, Free Energy has been discovered, this electricity multiplier mechanism is dirt simple, and extremely easy to build, with spare parts even. Building this type of free energy device is not only easy, but is simple also, costing practically nothing to produce. This is mainly because you are able to build this contraption with spare parts, and very few parts at that.
   This device is extremely easy to build, with only a few moving parts, such as at least two pulleys, one large pulley, one or many small pulleys, and a belt, strap, rope or even string in a pinch, to connect the two pulleys together. There are only two more moving parts here, a DC drive motor, and at least one AC output motor/generator. I say at least one, as you could have many more, as the more generators you have, the greater the multiplication factor of your electricity multiplier unit. You can also increase your multiplication factor by increasing the circumference of your drive pulley, or decreasing the circumference of the output pulleys.
   The workings of this miraculous mechanism are pretty straightforward, and can be described by using a multiplication factor of rotations, by merely changing the size of pulleys. You put an extremely small amount of DC electricity into the drive motor, which has a 100cm circumference and only needs to do one single revolution. This drive pulley is connected to at least one one-centimetre circumference mini-pulley that acts as an output device, giving us 100 units of AC electricity, per every output pulley that is connected.
   I suppose that you might be able to see how this could start adding up, giving you 100 units of AC electricity for every output mini-pulley that you attach to the system. If you only added 10 of these mini-pulleys, then you would gain 1000 units of AC electricity, for every single input revolution of the DC motor that you put into this free energy device, otherwise known as GEM = Geometric Electricity Multiplier
that_prophet
·   THIS DOES WORK !!!
It just takes you to look past the lie,
That evil forces are whispering in your ear,
It is pure logic, that pulleys multiply rotations,
+ with AC electricity, revolutions equal AC power,
Satan hides this super simple free energy technology,
By immediately bringing up torque needed to rotate pulley,
Letting you forget AC motors are a breeze to rotate,
You could easily have 10 – 100 of them rotating at once,
And when the drag of load attacks, it is minimized by 1/10th to 1/100th,
Because of it getting divided up, so it lessens it so severely, that it works
Please believe me, and my Lord + Savior, Jesus Christ,,,
God So Much Wants to Give us this Little Miraculous Device,
+ He only ask for your faith,,,
that_prophet
Quote from: FatBird on June 12, 2014, 05:02:31 PM
OK, I have the worst hen-scratch,
but this is after an accident that killed me twice,
with brain damage of lack of air for I don't know how long
including a pretty severe closed head injury
where I had to relearn how to speak even,,,
+ my hands shake un-voluntarily
PLEASE GIVE ME A BREAK !!!
LOL
that_prophet
Quote from: memoryman on April 17, 2014, 03:34:22 PM
energy can neither be created nor destroyed. If you can demonstrate otherwise, you deserve a Nobel prize.
Energy multiplication/magnification is equivalent to creation, so that can not be done either.
All you do is increase the speed and simultaneously decreased the torque, resulting in the same power (minus the losses).
