I have a working free energy device
Started by one_christian_warrior, January 05, 2013, 03:20:51 PM
that_prophet
Here is GEM = (Geometrical Electricity Multiplication) a simple free energy technology
for the Tribulation Saints = (which could be easily built, out of a large pulley with a DC drive motor + a mini-pulley on at least one AC generator, to be used as a multiplier)
http://free-energy.yolasite.com/
((( NEWS of this ancient technology will change the world )))
I have the MOST IMPORTANT NEWS
To share with you + this whole world. Unfortunately this NEWS has two sides to it, one side is the best, most awesome God Given Gift, and the other side is the most horribly scary kind of news. THIS BEST NEWS is that FREE ENERGY is easy to produced, and can + will even lead to anti-gravity. Yes, that's right, this GEM=(Geometrical Electricity Multiplication) technology will eventually lead us to a way of defeating + repelling gravity. PROOF = this tech is found in our Holy Bible, (Ezekiel 1:16- where it is describing the appearance of a working UFO motor)
This FREE ENERGY technology is so simple to explain + build + use, you will wonder how it has not been discovered earlier=(evil forces were + are hiding this free energy technology). With this super simple technology, you only have to put one spark of DC electricity into this GEM=(Geometrical Electricity Multiplier) mechanism, to get a return of 100's or even 1000's of units/cycles of AC electricity. That is because you only need to rotate your DC drive motor once,(costing only one spark of DC current) with a 100cm circumference pulley attached. This large pulley is attached to a long belt, strap, rope, or even string,(in a pinch) strapped around your 100cm pulley + 10 mini-pulleys with only 1cm circumferences, + each mini-pulley has an AC generator attached to it. This GEM of a mechanism runs by converting the 10 X100 = 1000 units/cycles of AC electricity = duel sparks, into much more than the one single spark of DC electricity that you need to power your drive motor, by using full wave bridge rectifiers. (one for each of the AC generators)
This free energy technology works by only having to put one spark of DC electricity in, which can return you 1000's of spark cycles, or units of AC electricity out. It's truly that simple, you are seemingly breaking the laws of thermodynamics, by using many small pulleys to multiply your total # of rotations, which you can easily convert into AC electricity. These AC generators run practically free of any torque, as you only need to produce one spark of DC current, (practically zero current) + torque is caused by producing power, which is P=AV, or Amps=current multiplied by Voltage + massive voltage times practically zero current, still equals practically zero torque. Then by using full wave bridge rectifiers, you can also easily convert your AC electricity into a lot more than the one spark of DC current, that you need to keep this GEM of a free energy mechanism running = producing a lot more than is needed to be self powering. http://beliefstoliveby.yolasite.com/
These AC generators would run freely, as torque is caused when you're producing power, and since P=IV, or power is equal to current=(I) times (V)oltage, there is practically no power being produced. I can say this, considering that the only current you need to drive your DC drive motor, is merely one spark, or practically zero, and zero times anything is still zero. For this reason, I believe that these AC generators would take practically zero torque to rotate.
This technology is in the Holy Bible = in Ezekiel 1:16 where he is describing what a UFO motor looks like while it's running so this technology will eventually lead us to anti-gravity as well as not only speeds approaching the speed of light but also the ability to do 1000 kph vectoring
I have already had one person confirm that this GEM technology does indeed work, as he said that he built three different versions of this free energy technology, that do indeed work. He was worried about the rumors that anyone who actually built a working free energy mechanism was soon after found dead. So, because he feared for his life, as well as the lives of his family, he asked me to not give out his name, or the fact that he had built three working versions of this GEM, free energy technology.
pulp
If you are so confident it works why not pay someone to build it if you can't? Or someone pays you to flood this forum with this bible crap?
that_prophet
you only have to input the DC electricity to rotate your large bicycle wheel once, (1 meter circumference)
which with a DC motor is only one spark of current, (to rotate it one full time)
+ then you get to have an output of 1000 cycles of AC electricity, (or the circumference of a bicycle wheel)
for every 1 millimeter circumference mini-pulley that you attach to the system,
and attach an AC generator to, (you would get 1000 cycles of AC electricity)
if you chose 10 mini-pulleys, you would get 10,000 units of AC electricity,,,,,,,,,,,,,,
HOW COULD YOU GO WRONG
this is so simple, that it is ridiculous that we have not figured this out earlier
(this is proof that there MUST be an evil force that is desperately trying to hide this tech from us)
Remember, these mini-pulleys with AC generators attached take practically zero torque to rotate,
as they only need to produce one spark of DC current as output, (after running your AC output though a full wave bridge rectifier)
+ torque is caused by generating power, which is P=IV, and no matter how much (V)oltage you wind up,
it is still multiplied by practically zero current, (you only need one spark) to keep this running
massive
massive
Jr. Member
Re: I have a working free energy device
« Reply #74 on: November 29, 2016, 06:44:58 AM »
Quote from: that_prophet on November 18, 2016, 12:42:42 AM
(TOTALLY CHILDISH RESPONSE = I HAVE 3 YEAR ELECTRICAL ENGINEERING TRAINING + 1 YEAR OF COPUTER GRAPHICS SPECIALIST + 2 YEARS OF INFORATION TECHNOLGY + WITH 5 POINTS NNISSING ON ONE COURSE - TO HAVE HONORS IN THE LATEST SCHOOLING THAT I HAVE HAD) = AFTER THE CLOSED HEAD INJURY
ALSO - TO GET OUT OF A NURSING HONNE AFTER A SEVERE CLOSED HEAD INJURY = WHERE I DIED TWICE + THEN WAS DECLAIRED BRAIN DEAD = THEY CUT OFF THE LIFE SUPPORT + I WAS BLESSED ENOUGH TO START BREATHING ON NNY OWN.
IN ORDER TO PROVE NNYSELF CAPABLE TO LIVE ALONE IN AN APPARTENT I LEARNED THAT I HAD TO PROVE NNYSELF  CONNPETANT-(ABOVE 85) = SO I TOOK 2 IQ TEST = SCORING 135 ON A TEST RATED ACCURATE UBTIL 120 =(+15 ) + A 165 ON A TEST RATED ACCURATE TO 145 =(+20)
HOW DO YOU EXPLAIN AWAY THE GETTING 1000 CYCLES OF AC ELECTRICITY................ ALL WITH AN INPUT OF ONE SPARK OF DC CURRENT
no electrical training teaches DC quantity as a spark or
DC electrical input into any device as a spark .
DC motors dont run on sparks .
current is measured in amps not sparks .
what was the name of the tutor , teacher , professor that taught you that?
= UN ANSWERED                (Quote isnt working so had to copy)
that_prophet
EVil-sOLUTION - free energy can be found in a UFO motor description in Ezekiel 1:16
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year peace treaty with Israel MUST START before the Door closes on 2019.04-"know that it is near, even at the doors" Mat 24:33   http://doorschristmustpassthrough.yolasite.com/ . DOOR = (Christ must return before date) We were given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel offspring with women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood.
What is AC electricity, + how is it made, out of rotations of a coil of wire through a magnetic field right, + a set of varying sized pulleys, can be easily used to multiply the total # of rotations. This is one free energy technology that we all will need and love = no cost, fuel or exhaust. So,,, why haven't we figured this simple little bit of technology. Can you believe the power of evil spirits, to be able to dumb down a whole population of humans. Think this may be a reason to find God http://beliefstoliveby.yolasite.com/
Do you want to hear how super simple this technology is,
Where you only pay to crank over one time, the DC motor + one 100 cm circumference pulley,
Then you use the 100 cm of moving belt off this large pulley circumference ,
+  run it past 10 mini-pulleys of only one centimeter circumferences,
All that you have to do is add AC generators to these 10 mini-pulleys,
Giving you a free return of 10X100=1000 cycles of AC electricity.
That's one small pulse of DC current as an input, returning you 1000 cycles of AC electricity,
You are using the dirt simple laws of pulley mechanics to multiply rotations,
+ since AC electricity is generated by simple rotations
Believe it or not, you are using this pulley mechanics, to freely multiply your AC electricity
+ you could easily multiply your AC cycles of electricity
IT IS TRULLY THAT SIMPLE..................................
You are using simple Pulley mechanics to multiply AC electricity cycles
And don't you believe that torque is a problem,
You have 10 X 100 = 1000 cycles of AC electricity,
To make up the one spark of DC current that you need,
That this DC drive motor needs to be cranked over the one time,
Giving you the 100 cm of moving belt = off 100 cm circumference,
This motor – generator power system is self powering,
It can do this by creating massively more electrical power from your many # of AC cycles,
That you can produce from your many AC generators, attached to many of these mini-pulleys,
Which are so easy to rotate, because it does not take 100 times more power to rotate a large pulley,
Yet this large pulley gives you 100 cm of moving belt off one single rotation,
Which by passing by 10 mini-pulleys with AC generators, can produce 10X100=1000 cycles of AC electricity, thereby multiplying your total amount of cycles of AC electricity,
By only needing a miniscule amount of DC current to rotate only once,
+ producing as many thousands of cycles of AC electricity, as you added the # of mini-pulleys,
With AC generators attached
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS
+ how powerful this spiritual warfare must be,
to be able to hide this super simple AC multiplier from us gullible humans..............
We can use pulley mechanics to freely multiply rotations,
Thereby we are using pulley mechanics to multiply cycles of AC electricity
I don't know about you, but I was amazed at how simple this preschool way of using pulleys to multiply your # of rotations, thereby multiplying AC electricity by using this simple pulley technology. And can you believe the power of evil forces, to be able to hide this super simple way of using pulleys to multiply the total # of rotations, or AC electricity. For how long,,,,,,,,,,,,,,,,,,,,
Think about this, for how long have they been able to hide this free AC multiplying technology,,,,
The thing is, that there is the most powerful spiritual warfare going on about this simple free energy technology, and evil forces will immediately start confronting you as soon as you start looking into this. I can be sure that evil forces will whisper in your ear, many ways that this cannot possibly work. For why should evil spirits want us to be able to stop buying oil, from nations that in one way or another tend to promote terrorist, and their careless destructive ways. I believe that God gave me this technology back in the early 2000's when He first gave me a Vision of a 10 speed bicycle going uphill in 10th gear, and then back downhill in 1st. This is very significant where AC electricity is concerned, where you may need massive voltage, to crank over the pedals on the way up, but it costs way less current, as the motor runs for only a few rotation. Then when you run the bicycle down the hill in 1st gear, you would be winding over your AC generators massive amounts of time. Please remember that AC electricity is generate through rotations of a coil of wire through a magnetic field, and the more rotations means more AC electricity.
http://possibletimingfortribulation.yolasite.com/
here is one of the forums that my GEM pulley free energy
http://evotutionfairytale.yolasite.com/
(here is a picture that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1-3 not 4)
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started. Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,,
Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6 + 9 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies the bird, + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that fund terrorist. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, that would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
http://my2020vision.yolasite.com/
http://fire-starter.yolasite.com/
This pulley technology works,,,
Here are a few of ideas that others have,
Knowing or not knowing that it is based on the same GEM technology
but just watch + learn THESE DO INDEED WORK
GEM technology is true free energy, except for that former President,
That switched the patent law to be more accessible to others
+ In theirs it only has one mini-pulley, + not 3 or 10 like in mine
https://www.youtube.com/watch?v=IjN1refTtHg
https://www.youtube.com/watch?v=A1ZGOgcZp_g
https://www.youtube.com/watch?v=RD2GrpBIMXc&t
+ you can be sure that more people will come out with their own GEM tech
mankind will hopefully move quickly with this new found pulley technology
where in no time, people will be starting up factories to add this free energy tech
to all electronics + electric mechanisms + yes, even automobiles,,,,,,,,,,,,,,,,,,
can you imagine cars that don't cost any fuel to travel, any amount of distance you want
+ think of how the cost of everything will go down, with no fuel costs to transport stuff,,,,,,,,
PLEASE DON'T FORGET, THIS FREE ENERGY MECHANISM WAS FOUND POWERING A UFO
in Ezekiel 1:16, so we need to experiment with this tech, + see how it can be used in levitation
Quote from: memoryman on June 12, 2014, 01:14:54 PM
I suggest that you take some courses in elementary physics and electricity. Don't abuse the Bible; it has nothing to do with belief.
