Tesla Patent # 577670
Started by Goat, January 09, 2013, 05:25:40 PM
forest
Good that this link still works http://sssf.byethost31.com/physics1/13961.htm
the obvious should be to you that bee is from outer spacetime ;-) where times goes by faster
the difference in time makes OU
forest
"It is then discovered that the flexibility of the wing plays a significant role as well as the mechanical movement of the wing through the air and the speed at which the wing is flapped. "
;D
totoalas
 for a pulser ive once made a cap relay pulser one 12 v dc relay and a cap in a fluorescent ac lamp
in nc mode the cap is charging back the relay
if somebody can simplify the circuit or parts off the shelf then we can start the build   startingwith the coil  then pulser and transformer
shylo if you can share yours will be fine   and others too
shylo
Mags' ,I'm not even sure it is shorting ,in the wrong spot the contact melts, in the right spot it still sparks ,but a different colour ,also the wire doesn't even get warm..picture I hope
Toto ,This is what I need ! Some way to dump caps in sequence?
Here are 2 coil stacks 1 on top of the other..
Each stack seems to be limited to 7 bridges.
More testing yet to do...shylo
crazycut06
Hi all,
This is my rough sketch of the patent with the revised switch, this switch may not be correct compared with the patent where the commutator at some point is both connected through coil k, the switch can be a DPST relay or mosfets, i've put the coils "o" on the secondary side which i believe they should be to pickup the kick from coil K, however, i don't know the effects of the reversed windings, how they work with the consensers or caps "maybe polarized or non polarized", maybe the caps should also be reversed dunno....
I know many have done this before like Mags,  ;D  Let's explore it further... Whats your take on this?
