Thanks to ALL for your help!!
Das Triumphirende PERETUUM MOBILE ORFFYREANUM
Started by circle, February 04, 2013, 02:11:10 AM
circle
the way people study this matterial is misleading them into overlooking what can be done
https://en.wikipedia.org/wiki/Rotation_around_a_fixed_axis
these are some of the concept that figure in significantly
https://en.wikipedia.org/wiki/Improper_rotation
https://en.wikipedia.org/wiki/Pseudovector
https://en.wikipedia.org/wiki/Angular_momentum
if you know what you are looking for you can see that the discussion is (deliberatly?) being limited to topics that can not result in the outcome that we all seem to have come to this website to either research, prove or reject
circle
its pretty basic once you see what is taking place
for solving the device one of the first elements of data is the fact that people saw the weights
the cylinder shape seems to indicate the orientation of the weight inside the device
and the fact that people saw him try to fit a weight in place when instead the tension on the spring was accidentaly released with a slaping noise and a twanging spring noise
consider the small hole that was left for access and his comments about same when 'detractors' inquired
these clues can be exained in considerable depths
i hate that i have the solution for the bessler wheel and that i have still done nothing with it
it would be one thing if i were stating that i knew how to set something into a balanced motion.. the principal of that might be debatable
but to actually produce useful additional energy the concept has to be solid
as basic as it is, the process still seems to be beyond the conceptual grasps of most people
it has the effect of folding the looping path of the weights over with between .2 and .25 of the weight set in motion left hanging into empty space
circle
...perhaps i hate even more that no one from amoung the few here are able to tell for themselves the solution to this device
as simple as this knowledge is.. it represents a world very different than the one we find ourselves living in
zoelra
Circle said
"...perhaps i hate even more that no one from among the few here are able to tell for themselves the solution to this device as simple as this knowledge is.. it represents a world very different than the one we find ourselves living in".
Just because no one here is proclaiming they have a solution is no reason to believe it has not already been found. Also, many here have learned the hard way that having a solution is not having a solution until you have a runner.
Regarding your most recent PM, sorry, I have attempted to grab all of Docs notes, of which there are numerous posts. It has turned out to be a more time consuming process than I thought. It's not a simple copy/paste process. I will keep at it though, if only for my records. Consider joining BW. You can search for all posts under his name. It makes for many hours of enjoyable reading.
