Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
barbosi
Quote from: saintsnick on February 05, 2007, 12:58:24 AM
I really don't know if Newman has anything to do with this.  Newman's motor is based on the similar principals of Edwin Gray's motors, Capturing Back EMF.  Newman uses huge inductances for a huge kick back.  His commutator only serves to cycle the field winding on and off and to direct the back emf, same as Gray.  Nothing to do with sparks causing OU.  ( I think)  Gray however used high voltage spikes to slap the coils.  Quick HV bursts, actually delivering less charge to the coils, yet causing momemtum and a very big back emf.
Gray DID however have a second device, a Spark emition and energy capture device.
Unless Newman had some other device, other than his motor.  Nothing of this on his web page.
In fact, Newman may have a spark device built within comutator. For reference, see the test results and comments at Naudin page:
http://jnaudin.free.fr/html/NMac0629.htm
I hope this helps, my self I'm still looking for answers and for now, I'm just taking notes on paterns/coincidences. So far, the *spark* looks to be the winner (IMHO). Why and how interacts with vacuum / aether is the big unknown.
When the Power of Love overcomes the Love of Power, there will be peace.
barbosi
For a better understanding, do you have a picture? switch and coils?
It's a bit confusing to me what secondary belongs to what primary (I understand the diagram is also a spatial representation...?...)
A functional description would help also along with timing diagram. Which coil fires, which coil recicles... I personaly don't understand the switch representation.
Thanks.
hartiberlin
Hi Erfinder,
where are exactly your primary and secondary coils located ?
It does not get clear from your drawing.
It would be good, if you could post some pictures too.
As we are going to have open source energy solutions over here,
all solutions should be published as complete as possible.
The one who can present a working prototype which will
run on its own energy will get many prices and fame.
I am trying to setup my own free energy device prize soon.
Stay tuned.
Regards, Stefan.(admin)
pese
Danke , das ist sehr ausf?hrlich um darauf zu arbeiten . Ich akzeptiere Deine Gedanken und Gr?nde , das Du Deine Informationen auf  diesem Wege abgibst . Es ist richtig , das  nicht jeder hier warten muss , um etwas kopieren zu d?rfen , sondern seinen eigenen Kopf benutzt  und seine H?nde um etwas aufzubauen.  Danke  Pese
Thanks, is to be worked very in detail over on it. I accept your thoughts and reasons, which you deliver in this way your information. It is correct, which does not have to wait everyone here to develop in order to be allowed to copy something, but its own head uses and its hands around something. Pese
http://ch.to/fe  deutsch  http://pese.150m.com/fe/ english  LINK WORK NOW !
orosado
Hi erfinder,
I await your paper. Thank you for all the information you have given us. You have given me hope that Free Energy exists and that the public may one day have this knowledge as a known fact.
Regards,
Omar Rosado
Quote from: Erfinder on February 13, 2007, 01:19:25 PM
barbosi, pese,
and anyone else interested
Hello,
The 144 inches is based on a 22.5mm inch.  ??? Yeah!!! I know how it sounds.  I in my researching I have learned of a measuring system used by the ancients. This system was brought to my attention by Wayne Thompson.  Information on this system can be obtained by reviewing his website.
Weights and linear dimensions are interchangeable, this being said anything goes.
www.themeasuringsystemofthegods.com/index.html
Quote taken from the site:
"The Three Metrics that are most common to Free Energy Devices are
1080/45 = 24 mm inch and the 1080/48=22.5 mm inch and the 1080/42 Metric.
The 25.4 mm Inch has NO scientific value as you are led to believe, it is only to deceive you."
I have not been able to locate where Tesla made the statement about the weights of his primaries and secondary coils, but the following quotes are very important to understanding my diagram and the patents which I suggested.
512,340
Coils for Electro Magnets
?I have found that in every coil there exists a certain relation between its self-induction and capacity that permits a current of a given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or in other words, as if it possessed no self-induction.  This is due to the mutual relations existing between the special character of the current and the self-induction and the capacity of the coil, the latter quality being capable of neutralizing the self-induction for that frequency.  It is well known that the higher the frequency or potential difference of the current the smaller the capacity required to counteract the self-induction;  hence in any coil, however small the capacity, it may be sufficient for the purpose stated if the proper conditions in other respects be secured.?
593,138
Electrical Transformer
?If the rate at which a current traverses the circuit, including the coil, be one hundred and eighty-five thousand miles per second, then a frequency of nine hundred and twenty-five  per second would maintain nine hundred and twenty-five stationary waves in a circuit one hundred and eighty-five thousand miles long, and each wave would be two hundred miles in length.  For such a frequency I should use a secondary fifty miles in length, so that at one terminal the potential would be zero and at the other maximum."
As I am constantly adding to and modifying my understanding it may take some time before my paper is finished; I hope that most who are viewing this can accept that.  I will not be rushed, nor pressured into exceeding my means.  Because it will take me some time I have no problem with answering a few questions I am no scientist, so my answers will not be in line with the mainstream view.  It should be understood that I am not trying to give the answers away, as this would not benefit anyone, including myself, I will however help where ever I can those individuals willing to modify their view, find the answers themselves, as they are here and have been here since the very beginning.  It is my opinion that a majority of what we consider fact is in fact nothing more than theory.  Until electricity, magnetism, gravity, and electrostatics and their relationships to one another are perfectly understood (by observing them in nature) no new technology can nor will come forward.
Review the diagram, study the patents, and take note of the above quotes.  All of these things combined are more than enough for anyone of any level to build a working device.
P.S.
I will not make photos, ever, so hate me or hate me.  I am sorry, but nothing anyone says will change this.  If this is not acceptable then I will leave, this is not a problem, I am here to inspire, not to change the world.  The proof you require is within your grasp.  Study, and build!
