A Kapanadze generator replication - Febuary 2013
Started by tika, February 20, 2013, 03:55:50 AM
totoalas
http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out/msg333386/#msg333386
(http://www.energyscienceforum.com/images/misc/quote_icon.png) Originally Posted by John_Bedini(http://www.energyscienceforum.com/images/buttons/viewpost-right.png)T1000,
That is correct it is a double sided ax. I have done that in some of the units, Peter and I have a circuit that just did that of witch you speak, the results were mixed. Although I will do it again. I have see some different things when doing that, I'm not saying they are good or bad, just mixed. In 2000 Peter and I did almost the same circuit your showing in the post ,and I agree with what your saying. I must start somewhere here so I chose simple first. Please post a youtube showing your circuit working as I do not follow overunity.com. I'm sure everybody would love to see that.
Ok, here is my(and my friend's) story first:
Massive OU Claimed in Freaky Pre-Halloween Video
Here is same story In patents:
http://www.nuenergy.org/pdf/GB763062.pdf
Michel Meyer -- isotope transmutation electric generator
Here is the output oscillogram:
(http://www.energyscienceforum.com/attachments/sg-radiant-oscillator/583d1346442716t-sg-radiant-oscillator-pirmine-iskociojimas-pjuklas-50-hercu.jpg)
The basic principle is based two signals comming into two primaries of transformer and making magnetic domains of the core itself to resonate on 3D space rotation... It is way down to atom level (http://www.energyscienceforum.com/images/smilies/smile.png) The one thing here is, the transmutation nuclear process starts up and while atoms are transforming from higher isotope to lower, the huge amount of magnetic field and electricity goes out of it. In addition there is neutron decay side effect. I just did find out and only recently about possibility to avoid this and stay way below of atom destruction level while still having strong magnetic oscillations... The way to it was probably found by one Russian scientist recently(still needs verification): 1) the first signal - the highest driving current and lowest possible voltage is from serial LC resonance in inductor
2)the second signal - the radiant spikes come with much higher frequency joined together into single wire just those are on 180 degrees to current phase.
Here is principal schematics for basic understanding:
(http://www.energyscienceforum.com/attachments/sg-radiant-oscillator/584d1346442948t-sg-radiant-oscillator-mix-bemf-reactive-current.jpg)
(http://www.energyscienceforum.com/images/misc/quote_icon.png) Originally Posted by LesK(http://www.energyscienceforum.com/images/buttons/viewpost-right.png)Running magnetic fields against each other is something I had never considered as a part of the SSG before.
LesThis whole area was re-discovered and forgotten more than 80 years ago...
The one of pioners in this area was E. Leedskalnin with his magnetic generator:
http://www.hyiq.org/Library/Download...ic-Current.pdf
Edward Leedskalnin's Perpetual Motion Holder
http://www.leedskalnin.com/Generator.jpg
LEEDSKALNIN.COM: MAGNETIC CURRENT RESEARCH
Above quote from t 1000
I think this was also achieved by Peter Linderman   not on the primary but on the output    using hv diodes in source positive to the HV output of ignition coil
gyulasun
ZVS oscillator driving a DC television flyback transformer like that one above:
http://www.youtube.com/watch?v=4XRwlNCF1PU
The circuit is the standard ZVS circuit that has been posted several times above, using IRFP260 mosfets.
A very similar circuit is indeed used in induction furnaces, but operating at a lower frequency.
Another simple variant of this circuit, at higher frequencies, makes a wireless power transmission system, as I've shown in a bunch of other videos.
The ZVS oscillator itself in this system is driven by 24-32 volts and is only supplying the 5+5 turn primary with a few tens of volts p-p and isn't dangerous itself. But the output of the flyback transformer is 20-30 kV and will kill you quickly, set stuff on fire, etc.
zcsaba77
Hi for All
On the bottom on this link, is Tesla draw:
http://freeenergylt.narod2.ru/lithuania_experiment/
how works together 12Hz and high frequency? how we can gain energy? maybe spark gap is adjusted to 12 Hz  ???
totoalas
