Thanks to ALL for your help!!
Graphene Made at home, producing voltage. Sharing all with you tonight.
Started by Hope, February 27, 2013, 01:33:55 AM
Hope
I had posted this on an obscure listing,  but I am certain anyone truly interested in converting voltage from the environment should read my recent success.  This is repeatable and based on the fore front of Graphene science.   Graphite Oxide mixed with water then coating a normal lightscribe DVD top.  Let it dry then write the label side you coated fully with full black print.  This turns the graphene oxide into graphene.  It is that simple.    Before finding the Rice University video on the above data I had success trying various non acid solutions, the only real voltage produced was minor  but to me it meant it worked.  So isn't that what a prototype is for?  Proving the idea works.  This is what I have been looking for since before I found this great forum.  Perhaps you all can accept this fact!!! IT IS SIMPLE and you can do it as well.   Comments are welcome.
Well, my duplication (not replication due to the "mystery fluid") took 3-4 days to deposit the carbon graphene layer.  It also did not work until I changed from a compact florescent to a dark blue led light for 36 hrs.  BUT then I got a 1 millivolt to 2 millivolt constant charge.  The non acid solution I found to work was two tablespoons of epsom salts.   I want tovideo tape this for the forum but do NOT wish to place it  on YouTube  (no thanks).  Though the output is small it means everything from nothing to me.   I used a carrot juice (bolthouse) bottle.  I know that size bottle vs the small output is lacking,  BUT this was after all just a prototype.   Look how large the first computers were and now look at smartphones that double at being handheld computers.
I am excited about this reactor  (really I don't even know what to call it yet).  I purchased KOH but got no reaction with using it as a solution to begin the layering of nano carbon tubes.
I sourced a lab for nano film on copper but they wanted 600+ dollars for a 2X3 inch strip.
We might very well be MUCH better off developing our own room temp. nano tubes.  Smile you all because if I can do it anyone can!
e2matrix
Hope,  that's impressive work.   One thing I wasn't clear about in your description involves writing in black to the DVD after putting graphite oxide mix on it.  Are you saying to use a DVD burner with labeling capability to make a solid black label on it ?  Using lightscribe ?   Any detectable amount of milliamps or microamps ?   Between what 2 points are you reading voltage?
Pirate88179
Excellent work.  This is what some major research universities are doing.  The wavelength of the light scribe turns it into  grahphene from graphene oxide.
Well done.
Lakes
If you don`t want to put the video on youtube (why not?) you can always upload it to one of the many file sharing sites like dropbox etc, or make a torrent of it.
Bruce_TPU
Hello All,
There was a Youtube Video yesterday made by the two inventors.  Today it is gone, due to "copyright" infringement.  BUT... I do have a link that describes the process, step by step for anyone else interested in replicating.  Very facinating work!
Enjoy!
http://www.printedelectronicsworld.com/articles/dvd-burner-fabricates-micro-scale-graphene-based-supercapacitors-00005192.asp?sessionid=1
Cheers,
Bruce
