Simple Lenzless Generator
Started by Neo-X, March 06, 2013, 04:54:24 AM
Neo-X
Bruce_tpu what would you think about this one? Suppose i have spiral conductor and neomagnet attached to one side and insulated to each other but electrically connected from the shaft. The brush in the spiral conductor is linked to the brush of the neomagnet.  Then suppose we rotate it, the induced voltage in spiral conductor is much higher than the induced voltage in the neomagnet and causing the current to flow from spiral conductor, then to the shaft, then to the neomagnet, then to the brush and then back again to the spiral conductor.  According to faraday law and tesla, the spiral conductor doesnt produce lenz effect if both neomagnet and spiral conductor attached to each other or simultanously rotating. Neglecting the eddy current, the setup will not produce lenz effect but the current is flowing in the neomagnet making the neomagnet act as a motor producing a torque that aid the applied torque. So the rotation will increase as more current flow to the neomagnet and accelerating it untill the resistane stop it from accelerating.. See the idea A.. In idea B it was the same operation on idea A but this time it was using solid disc conductor and the brush from neomagnet was moved to the center radius of neomaget.
I forgot in idea A the brush doesnt need since both spiral disc and neomagnet are attached to each other and rotating at the same speed so we can connect both of them directly at the rim.
b_rads
@All:
This is something that might be of interest, the links below contain some information about the drag on the Faraday Disk and a possible solution of minimizing that drag.
http://callowayengines.com/msg50.htm
http://callowayengines.com/msg51.htm
On the second link, the author suggests making a capacitor on the outer rim of the coil/copper for harvesting the energy produced.
Bruce_TPU
Quote from: Neo-X on March 08, 2013, 04:18:00 AM
I like your thinking.  I am just not hooked on the spiral disc part, but rather I am hooked on the spiral tesla pancake coil.  With the disc you will produce a huge amount of amperage, but next to no voltage.  My idea of of using LITZ in a tesla pancake coil, would multiply the magnetic movement of electrons, increase the voltage, and possibly more, IMHO.  I had built all of the pancake coils some time ago, but before I understood the benefits of using litz in this situation, so I abandoned those built of very thick wire.
I encourage  you to build your idea and see.  That is the only real way of knowing.
Cheers,
Bruce
phoneboy
@ Neo-X, you should take a look at what the borderlands group did a while back.  They alternated the fields of the magnets on each side of the disc and were able to get an ac output.  With that you could get away without using brushes @ all.
Neo-X
@phoneboy
How it could draw the current from the solid copper disc without brushes?
