PDi Regenerative Acceleration and BiTT Principles
Started by DeepCut, March 20, 2013, 11:49:44 AM
THANE HEINS
IGNORANCE IS NOT BLISS PART DEUX
AS PART THE DISPENSING OF IGNORANCE ON THIS FORUM - THERE ARE TWO ANOTHER IMPORTANT ENERGY CONCEPTS THAT NEED TO BE ADDRESSED.
1)
EVERY SYSTEM IS 100% EFFICIENT.
ANYTHING FROM A MOTOR TO A MATCH FLAME IS 100% EFFICIENT.
THE LAW OF CONSERVATION OF ENERGY INSISTS THAT ENERGY CANNOT BE CREATED OR DESTROYED - JUST CONVERTED FROM ONE FORM TO ANOTHER.
THIS MEANS THAT IF YOU ACCOUNTED FOR ALL THE CONVERSION OF ENERGY IN ANY SYSTEM (TO HEAT, NOISE ETC.) THE OUTPUT WILL ALWAYS EQUAL THE INPUT AND THE SYSTEM WILL ALWAYS BE 100% EFFICIENT. IT HAS TO BE... ACCORDING TO THE LAW OF CONSERVATION OF ENERGY.
2)
THE LAW OF CONSERVATION OF ENERGY IS FALSE AND HAS ALWAYS BEEN FALSE IN ANY ELECTRICAL SYSTEM IF A BEMF MAGNETIC FIELD IS CREATED. BECAUSE THIS BEMF ENERGY CAN AND DOES DO WORK...
EVERY GENERATOR, EVERY TRANSFORMER, EVERY MOTOR OR PIECE OF WIRE THAT PRODUCES BEMF IS ALREADY AN OVER-UNITY DEVICE.  ;)
THE ABSOLUTE (NON-DIRECTIONAL) VALUE OF ALL THE ENERGIES CREATED ALWAYS EXCEEDS 100%.
IF WE LOOK AT A GENERATOR ON NO-LOAD FOR EXAMPLE IT IS ALWAYS 100% EFFICIENT.
ALL THE INPUT ENERGY IS BEING CONVERTED TO AN OUTPUT OF MECHANICAL ENERGY, HEAT, NOISE ETC...
WHEN THE GENERATOR IS PLACED ON-LOAD THE MECHANICAL INPUT IN THE DRIVE SHAFT IS CONVERTED TO ELECTRICAL OUTPUT AND SOMETHING ELSE! SOMETHING OFTEN OVERLOOKED AND ALWAYS MISUNDERSTOOD (OR MORE LIKELY COMPLETELY UNDERSTOOD AND DELIBERATELY TWISTED).  :-X
THIS SOMETHING ELSE IS CREATED INTERNALLY AND IS A FORM OF ENERGY - THE SELF-INDUCED BEMF MAGNETIC FIELD WHICH CREATES AN ELECTROMECHANICAL COUNTER-TORQUE AND DECELERATES THE SYSTEM.
IF WE LOOK AT WHAT IS REQUIRED TO CREATE TORQUE (IN ANY DIRECTION) WE WILL SEE THAT FORCE IS REQUIRED TO CREATE TORQUE AND DO WORK AND IF WE LOOK EVEN FURTHER WE WILL SEE THAT ENERGY IS REQUIRED FOR A FORCE TO BE PRODUCED AND DO THE WORK OR TWISTING ACTION. http://hyperphysics.phy-astr.gsu.edu/hbase/torq.html
NOW IF WE ADD THE ABSOLUTE VALUE OF ALL THE NON-DIRECTIONAL ENERGIES IN THE SYSTEM... THE GENERATOR OUTPUT + THE COUNTER TORQUE WE WILL SEE THAT THIS ALWAYS EXCEEDS THE INPUT ENERGIES.
EXAMPLE IN ANY CONVENTIONAL GENERATOR SYSTEM ...
NO-LOAD INPUT MECHANICAL POWER = 100 WATTS
NO-LOAD EFFICIENCY,
INPUT ENERGY - RESISTANCE + POTENTIAL KINETIC ENERGY / INERTIA = 100% EFFICIENCY
ON-LOAD GENERATOR OUTPUT = 10 WATTS
ON-LOAD INPUT INCREASE REQUIRED TO MAINTAIN SYSTEM RPM AND DELIVER 10 WATTS = 10 WATTS
NEW INPUT = 110 WATTS
BEMF INDUCED COUNTER-ELECTROMOTIVE TORQUE FORCING SYSTEM DECELERATION (AND INPUT INCREASE) = 10 WATTS
NEW ON-LOAD INPUT MECHANICAL POWER = 110 WATTS
GENERATOR OUTPUT = 10 WATTS + BEMF INDUCED TORQUE ENERGY (10 WATTS)
FOR EVERY 1 WATT OF ENERGY DELIVERED TO ANY LOAD AND EQUAL 1 WATT OF COUNTER-ELECTROMOTIVE TORQUE ENERGY IS ALSO CREATED...  ???
TOTAL ON-LOAD OUTPUT = 20 WATTS
TOTAL ON-LOAD INPUT = 10 WATTS
EFFICIENCY 20/10 X 100 = 200%  8)
REGARDS
T
Thane C. Heins
President & CEO
Potential +/- Difference Inc. R & D
"Change catalysts using our potential to make a positive difference"
Email: thaneh@potentialdifference.ca
Cell: 613.795.1602
YOUTUBE http://www.youtube.com/user/pdicanada1
Linkedin http://www.linkedin.com/profile/view?id=107557432&trk=tab_pro
slideshare http://www.slideshare.net/ThaneCHeins
THANE HEINS
Quote from: brownlake on March 23, 2013, 08:02:11 PM
why do you write with all caps ? it's more difficult to read
TO MAKE IT MORE DIFFICULT TO READ...
AND TO SLOW DOWN THE READING PROCESS TO REDUCE SKIMMING AND ENHANCE ABSORPTION.
TO ENCOURAGE CONSCIENTIOUS READING AND FOCUS RATHER THAN THE BELOW...
I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg. The phaonmneal pweor of the hmuan mnid. Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit pclae. The rset can be a taotl mses and you can sitll raed it wouthit a porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe. Amzanig, huh ? Yaeh, and I awlyas thought slpeling was ipmorantt ! Tahts so cool !
DeepCut
no way man, dnot wtrie lkie taht wehn im durnk !
hoptoad
Quote from: THANE HEINS on March 23, 2013, 05:25:00 PM
snip...
snip...
O/U by (-)81.2%. Slightly better than your results a few years ago. Now you've only got to recoup another 81.201 % to be O/U
Newton II
Dearest  Thane Heins Sir,
You should feel lucky to make your postings in ignorant forums because if you make such postings in knowledgible forums, people reading it may fire you with bad words.
Such sort of efficiency calculation may be taught  only in Ottawa University as a part of latest developments in mathematical physics.   I am an old man, studied in old school of physics where I was taught that overall efficiency of any system is the ratio of overall output to overall input.  As per your above description,  no generator in this world would have overall efficiency more than 50%.   If you tell the same thing to a generator manufacturer,  he may also fire you with bad words.
http://www.powerelectricalblog.com/2007/03/generator-efficiency.html
