I Cube Transformer
Started by icorex11, March 26, 2013, 09:47:25 AM
icorex11
here  are a few more picture of a compleat spinner pulse wire  fully wound  on an ICUBE core
icorex11
here is the ICUBE  spinner  both halfs wound 1 wire oppisite dirrections  there is 20 laps of 4 turn/ lap for a total of 80 turns each on both cores  clockwise and counter clockwise  this winding configuration MAKES A SUPER STRONG MAGNETIC FEILD ...
so strong infact .. that i broke 5 legs off this core i have since then had to repair the core with epoxy  just a word of caution do not let the 2 halfs crash togather i only applyed 12 vdc to the spinner and they slammed  into each other  the pull force on the one i had powered was so strong it yanked it out my hand ...  KOOL!
ARX11
icorex11
so in the next picture you see that i made a bobbin of cardboard to wind a secondary on...
so i wound the secondary 22 gage magnet wire 150 turns in 5 layers starting at 40 turns ..   it wound well in my next pic you see the bobbin set in place  all i did to wind the coil was found a solid square shape the bobbin fit on perfectlly  i then hand wound it
in the last picture you see the 150 turn secondary in place on the ICUBE core
i will be placeing 4 secondaries on the leggs aswell
ARX11
icorex11
so now i will place the 4 secondaries on the ICUBE spinner thease 4 secondaries will be wound on bobbins .. the bobbins i have found are from a dollar store  they were used to hold coloured craft wire they did not cost much ...
i will wind 30 gage magnet wire on them in a usual AC winding configuration ..  typically left to right layer on layer ... incase you didn't  know ....  lol
so here is a picture of the bobbins i will use and they will be wound for high voltage high freq ...the spinner is designed for  low voltage supply ....
ARX11
icorex11
so thats great then we have a blank bobbin and i dont feel like hand winding it .... yawn ...
so here is what i have done here is a simple cheep bobbin winder ..  i payed like $4.95  for it  i just added electrical tape to center the bobbin .. here are 3 pics showing the winder it goes in a cordless drill...
ARX11
