Big try at gravity wheel
Started by nfeijo, May 03, 2013, 10:03:04 AM
MarkE
Quote from: Marsing on February 15, 2014, 05:29:35 AM
In simple word
" webby need an amount of "external energy" to transfer "his energy" from one place to other  place"
"external energy" is an energy which webby must pay along transferring,
if this "external energy"  was taken from "his energy", you can quess the  final  result,
this  is the simple logic running on my head
but if using "magic method "  ........ .........    i would like to know  ........... ...........
Webby has cornered himself with a fantastic claim that he will not be able to support.  He has never had a means to perform the transfer retaining the original energy.  It is only in the past day or two that he even realized the energy transfer problem after it was pointed out to him.
As to whether shuffling about half of the "air" from the charged cylinder to the uncharged cylinder means that absolutely about one half of the the energy must be lost to heat, that is a bit more complicated.  What is absolute is that the stored energy post transfer in the combined cylinders is only about half what the pre transfer stored energy was in the first cylinder.  That dictates that the balance of the stored energy went into the transfer system.  If the transfer system met four requirements then it would be possible to reduce the losses.
The first requirement is that the transfer system would itself have to include a third energy store capable of taking up at least 50% of the energy of a fully charged first cylinder.
The second requirement is that the transfer system would have to be able to divert the energy that would otherwise be lost by a simple direct connection between the first and second cylinder into store with low losses, while still transferring the "air" from the first cylinder to the second up to the point of pressure equalization between the first and second cylinder.
The third requirement is that the transfer system would have to be able to divert that energy out of its store with low losses, while transferring the "air" from the first cylinder to the second after the point of pressure equalization.
The fourth requirement is that a control means  would be required that manages when to put energy into and when to take energy out of the store, and how much.
minnie
    Hi,
       not one of our three proponents has managed to come up with one fact in
     support of the ou. that they are allegedly claiming.
        It looks as if we've reached the bottom of the barrel. I'm sad because I
      was I was hoping one of them would have come up with something original.
       I wonder if Mondrasek will manage to turn anything up with his efforts, he
       seems to be taking care and asking for help when he's unsure.
                                  John .
MarkE
Quote from: minnie on February 15, 2014, 09:37:03 AM
    Hi,
                                  John .
After six years, HER / Zydro continue to have nothing but hand waving.
I am interested to see how Webby is going to respond.
mondrasek
Thank you, "minnie."  Is there any chance that you can assist by checking my work as I have requested?  Because unless I've made some mistake in the math, or the analysis process, I think I have uncovered something very interesting.  At least it is interesting to me.
M.
MarkE
Quote from: webby1 on February 15, 2014, 10:06:39 AM
Well MarkE you are putting miss-information out once again.
These are a few posts.
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386204/#msg386204
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386349/#msg386349
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386367/#msg386367
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386475/#msg386475
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386568/#msg386568
First pic from MarkE that has the air where it belongs,,, why did he change it later?
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386740/#msg386740
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386819/#msg386819
Now the setup is changed,,why?
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386893/#msg386893
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386922/#msg386922
I correct MarkE's error.
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg386998/#msg386998
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg387041/#msg387041
Me identifying the transfer pump.
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg387138/#msg387138
http://www.overunity.com/13480/big-try-at-gravity-wheel/msg387140/#msg387140
MarkE blowing off the description of the transfer pump.
I have described the method, it is not my problem if MarkE can not understand a simple pump system,, but since he is now saying that I can NOT move a pocket of air without loosing 1\2 its potential,, that sounds fairly foolish doesn't it.
If you care to pay attention you will see that the system is 3 independent systems, pump, source and discharge and it is only the pump that sees all 3 parts.
Webby anyone who followed the thread could see that I took your descriptions and changes as you dribbled them out one at a time and posted drawings accordingly.  Anyone can see the sparse sketch that you threw out at the start.  Anyone can read the thread and see that you threw a fit when I proposed changing the piston height by less than 0.01% so that at least a miniscule bubble that you said you wanted would actually always be present between the top of the piston and the underside of the cylinder top.  And anyone can see that over the course of some eight days you still never produced a full description of your test set-up despite your promise to do so Feb. 3.
This is the description you offered of the transfer pump:
QuoteI use a straight transfer pump connected between the top of the 2 cylinders, a transfer pump is a sealed chamber with a piston in it so that when the piston is on one side the other side has enough volume to hold the medium of one unit, then when slid over to the other side it pushes that volume out and into the unit it is connected to and at the same time will pull in the medium from the unit connected to the other side of the pump. simple.
One can easily work out that from an energy stand point the pump as you describe it, in the best case approximates a simple tube during the time that the source pressure exceeds the destination pressure, IE during the entire pressure equalization phase.  During that time the transfer pump acts like a hydraulic lock.
Now that the energy loss during equalization problem is inescapable you offer nothing to support your claim that you have a means to overcome that problem.  It's all on you webby:  You can support your claims or come away looking very foolish.  Decide what you want to do.
