Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
synchro1
I received a message from Bob Smith, asking if I ever tried a "Mag Amp". I'm opening this new thread so everyone can benefit from  Bob's knowhow.
Here's Igor's bedini-magnacoaster video:
http://www.youtube.com/watch?v=mzNjAs3-9LA
Reply to your comment on: bedini-magnacoaster:
My question to Igor was; Does the rotor speed increase when you insert the iron magnet into the coil core? His answer:
"yes, it does, a little...
to get to the bottom of it we need to make an inductor from it !
here's the Vorktex secret - by oscillation (it's his "breaker") get a HF HV output; transform it down to HF HA output and than rectify it to the caps bank; and discharge it to batteries to run the inverters to run the oscillator ... looped...
btw, like your antygravity tests...
cheers"
This confirms the rotor acceleration. The question remains, is this "Lenz Delay Effect"? My theory is that the magnet interferes with coil efficiency, inducing the delay! Extending the output coil core length appears to slow the coil's performance down too!
Here's Igor's video on the solid state "magnacoaster effect":
This experiment is basicly the same as the Dragone. Impulse demagnetization is generating OU power.
http://www.youtube.com/watch?v=MWhsJWXEER4[/size]
synchro1
JLN's 2sgen COP  13.7:
http://jlnlabs.online.fr/2SGen/html/s2genep7en.htm
Here's a link to Nickolay E. Zaev's paper. JLN tested COP of over thirteen:
l = ((Vdem^2)/10000) / ((Vmag^2)/10000) = ((35.2^2)/10000) / ((9.5^2)/10000) = 13.7
It is interesting to notice that N. Zaev has found a l = 16.3 with a Permalloy 81 NM core (look at here[/size]
The 2Sgen is a ferrite toroid core with magnets attached inside a pulse coil, and an output coil. All the same components as Igor's in his "bedini-magnetcoaster" video test! Remember; Igor's trifilar has a power coil, and an output coil just like the 2Sgen! Tickler makes 3!
synchro1
The combination of the OU demagnetization power from Igor's magnet core along with the rotor acceleration, however slight, proves conclusively that his abundant output is genuinely "Lenzless"! Generating this amount of awesome output power actually reduces the input power to the rotor! I got this setup to run itself and charge it's own source battery with diametric magnet core and a dipole rotor.
Here's one of the serial bifilar output coils and the stack of diametric neos I ran into the core:
Bob Smith
I thought a magamp might be useful for increasing the output of Synchro1's setup.
Useful intro to magamps:
http://teslapress.com/magamp.html
Another decent intro:
http://www.sparkbangbuzz.com/mag-amp/mag-amp.htm
A basic magamp serving as audio amplifier:
http://sparkbangbuzz.com/mag-audio-amp/mag-audio-amp.htm
Bob
synchro1
@Bob Smith,
                    Thanks very much Bob for your exciting links!
I think this experiment demonstrates more clearly then any how the Magnetic Amplifier works.
"To begin, I would like to first show a simple experiment that demonstrates how saturating a magnetic core can lower inductance and allow more AC current to flow through a lamp.
The lamp glows brighter when the magnets are near the transformer. The magnetic field saturates the core, lowering the inductive reactance in series with the lamp".
