Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
Conradelektro:
You believe that adding the red diode will route the collapsing field energy of the coil back to the battery (or the capacitor if you are using the capacitor.)
In fact this will not happen.  No recharging of the battery or the capacitor will take place.
Also, when you look at the original circuit, you don't need the FWBR, all that you need is a diode.
Please think about this and if you want to try to understand what I am saying as an exercise for yourself, more power to you.  For what it's worth, on many Mopozco clips he makes similar claims and they are also not true.  That means this is a common misunderstanding or misconception.
skycollection
Thanks Conrad, i am agreed with you, probably not work, but i always make experimentation, i will make the experiment and i will tell you what happens....! I think is amazing motor, this motor is not overunity, but with time and experimentation probably i can make an efficient motor.
1.- i have a question: i would like to power the motor with 18-24 volts, the question is how is the new value of the resistance (1K RESISTOR)to protect the hall sensor....? and what changes i must do in the circuit...?
2.- i would like to connect a second battery, (battery charger) can you show where are the new connections...?
saludos
Jorge
conradelektro
Quote from: MileHigh on June 24, 2013, 09:53:33 PM
Conradelektro:
I know that it does not work, see my experiments
http://www.overunity.com/13523/has-anyone-seen-lasersabers-new-motor-runs-on-1000uf-cap/msg363629/#msg363629
http://www.overunity.com/13523/has-anyone-seen-lasersabers-new-motor-runs-on-1000uf-cap/msg363634/#msg363634
Less relevant:
http://www.overunity.com/13523/has-anyone-seen-lasersabers-new-motor-runs-on-1000uf-cap/msg363504/#msg363504
http://www.overunity.com/13523/has-anyone-seen-lasersabers-new-motor-runs-on-1000uf-cap/msg363590/#msg363590
http://www.overunity.com/13523/has-anyone-seen-lasersabers-new-motor-runs-on-1000uf-cap/msg363599/#msg363599
Greetings, Conrad
conradelektro
Quote from: skycollection on June 25, 2013, 12:18:25 AM
saludos
Jorge
Hi Jorge,
attached please find your circuit for charging a second battery (the first battery drives the motor).
You are right, your circuit as it is now, should not be supplied with more than 20 Volt. The reason is that the Gate - Source Voltage of the IRF510 should not be higher than 20 Volt.
The Hall sensor A3144 can be supplied with up to 24 Volt (absolute maximum 28 V), so in principle you could use two stacked batteries (24 V - 27 V).
I will try to change your circuit for 24 V to 27 V operation.
Greetings, Conrad
