Amazing Coil puts out 200 V
Started by FatBird, June 11, 2013, 01:48:51 PM
FatBird:
You are the one that has to wise up.  You are simply believing disinformation and then repeating the same disinformation to others.  That is not a good place to be.
There is no "rotating field built in a magnet."  That's just a fantasy.  I am sure that you have learned that a coil only responds to changing magnetic fields.  And we are not referring to the fantasy rotating magnet fields here.  We are talking about changing magnetic fields like in a generator.  In the clips, you see hard drive magnets placed in coils were nothing is moving.  Therefore there are no changing magnetic fields and there is no voltage across the terminals of the coil.  Both clip are lies designed to persuade gullible people with a silly fantasy.  People on this forum should not be fooled by this nonsense.
The video you link to does not prove that there is a rotating magnetic field built into a magnet.  The plasma represents the flow of electric current.  The electric current is affected by the magnetic field of the external magnet and is deflected.  If you analyze the geometry between the magnet and the moving plasma that is inside the hollow cup you can see how it produces a rotating motor effect.  It's all due to the Lorentz forces acting on the moving plasma ions due to the external magnetic field.   In other words, it's just a parlor trick that looks cool, nothing more.
I will repeat to you, there is no "forever rotating field" associated with a magnet.  It's all just silly disinformation put out by people that are either con artists or they don't know any better.   A simple low-level con is to make a stupid YouTube clip full of lies to get views and get people to click-through the ads.  The clip might earn the person that made the clip $1000.  This person doesn't care if he or she is lying and spreading disinformation and confusing people.  That means nothing to them they just want the money.
mikestocks2006
Quote from: FatBird on June 11, 2013, 01:48:51 PM
Amazing Coil.
http://www.youtube.com/watch?v=cioxAXR6UoA
At around 0.17 in the video, notice that when he places the second magnet, the upper coil extension slightly moves off the white surface, but the wire to the light bulb is remaining motionless at the supposed solder joint. There is no solder joint there. The wire most likely goes through the surface to a separate power supply bellow.
The other coil extension did not move, but looking at that wire, and the apparent solder joint, the wire looks as it is rather pointing towards the surface instead of being more in line with the coil extension.
Agreed with TK, a possible motivation
...clicks and pennies doesn't hurt...
Thanks for posting the video.
Mike
e2matrix
Fatbird,  If you look through my posts you'll see I'm usually the one fighting against MH or TK and almost never saying never or being a naysayer.   But this is just fake through and through.   It cannot work.   Wire through the table or some such setup is how he's doing it.   I built one just like the original one like this that has so many youtube views.   I built it not because I thought it could work but because I happened to have all the parts right on hand and it was to prove it could not work and it was an exact replication right down to the shape of the hard drive magnets (I've got hundreds of them) and the alligator clips and wire gauge.   Took me all of about 5 minutes to put it together and not a hint of power of any kind not even a blip on the o-scope.   It's FAKE.   You've got to know I'm one of the last one's here to be calling fake but it really is just about as bogus as they can get.
Tito L. Oracion
Hi everyone ;)
now a days is very advance specially in film making like superman or some Chinese movie,
There are lots of flying scenes were in you will be amazed. but if you are watching film making, wow there are lots of harness, and they just edit it in the computer.
and superman perfectly flying in the air  ;D
FatBird
If anybody gets this working, PLEASE post some details so we can DISCREDIT the "naysayers" and Trolls.
PS:  For the last 6 years I see the SAME ole NEGATIVE guys posting NO, FAKE, NO, FAKE, NO, FAKE, NO, FAKE, NO, FAKE,
       doing their best to discredit honest inventions.
