Tragic accident with ball magnet EMDR motor-generator
Started by hartiberlin, June 22, 2013, 03:08:34 PM
synchro1
Quote from: hartiberlin on June 23, 2013, 11:17:18 AM
Hi synchro1,
can you please show a video of your device ?
Many thanks in advance.
Regards, Stefan.
http://www.youtube.com/watch?v=asTs_iuUbuM&feature=c4-overview&playnext=1&list=TLlx7cjHzBEmQ
Listen to the soundtrack on this video. I had had this running for a day and a half with the same zinging effect. Bouncing the power back and forth in resonance! No change in battery voltage. The big spiral's a trigger and power, and the smaller spiral's  wired to a FWBR then to the source battery.
http://www.youtube.com/watch?NR=1&v=YTjqcX6sigQ&feature=endscreen
Now that is interesting.
With the toroidal winding you should not be getting very much magnetic flux leakage, but you can be driving the core into and out of saturation, and also getting some additional augmentation from the field of the rotating sphere magnet.
In other words, you might have a core-effect pulse motor, self-triggering, with the internal spherical magnet as its rotor. It's like a Steorn Orbo core-effect pulse motor, only much better!
If, that is, I am right about it running from the core effect rather than flux leakage from the toroid acting as an electromagnet.
conradelektro
Quote from: synchro1 on June 23, 2013, 07:30:25 PM
I never understand why people who claim "no power consumption" never use a capacitor instead of a battery.
I would allow to start the device with a battery till it assumes "constant operation", but then a capacitor (which already was in parallel with the battery) could take over. Then one measures (e.g. every minute) the Voltage over the cap for a few seconds only (because the multimeter would be a load).
The capacity of a battery to drive a low power device is sufficient to do it for many days (and I have driven a Joule Thief with one AAA battery for almost 4 months), therefore "no change in battery Voltage" is a meaningless statement. It only shows "low power consumption".
It is specially bad if the tests are done with a 12 V 7 Ah battery (or even bigger batteries). To see a change in Voltage in case 100 µW are drawn will take many days and will probably be due to self discharging.
Greetings, Conrad
synchro1
The battery voltage drops noticably right away when I disconnect the feedback loop. This draw shows up instantly, it dosen't take days.  I don't need a capacitor to tell me what's going on!
Here's what I know for sure; Current can't flow in two directions at the same time through the same wire, but it can reverse directions. I use a number of magnet spheres of different sizes. The 1 1/2 " speeds up and slows down. Looking at this video:
http://www.youtube.com/watch?v=nEtnFn6TAzs
We can see the amp meter charging the battery as the sphere slows down and then reversing the current and draining the source as it regains speed. The charge coil then gains sway with an overwhelming back surge. That zither sound at around a hertz is the frequency of the charge reversal. While it's behaving that way in tight resonant oscillation, there's no further draw on the power source.
Even when the amp draw is rising and falling 3 100's each way, the base line voltage doesn't change. Think about it. At a steady R.P.M., once the charge coil's power reaches exchange level, there's no way for any other power to work into the circuit! The transaction is an even exchange from that point foward!
hoptoad
Quote from: synchro1 on June 24, 2013, 09:05:01 PM
snip...
snip..
Actually, in broad terms, currents can flow in opposite directions at the same time in the same wire.
But only those currents which are not deriving their emf from the same source at the same time.
KneeDeep
